电子发烧友论坛|
此设备无法启动。
(代码10) {手术失败} 请求的操作未成功。 以上来自于谷歌翻译 以下为原文 This device cannot start. (Code 10) {Operation Failed} The requested operation was unsuccessful. |
2个回答
您好ratchakan,感谢您在我们的英特尔®社区发帖。我知道您正面临着“此设备无法启动。
(代码10)“错误,让我们尽力为您提供帮助。为了确定您系统的状态,请向我提供系统支持实用程序将生成的.txt文件。 要附加文件,必须单击响应框右下角的“附加”选项。当设备管理器无法启动硬件设备时会生成错误,这种情况通常是由过时或损坏的驱动程序或 如果驱动程序生成设备管理器不理解的错误,则设备也可能会收到代码10错误。 Code 10错误可能是一个非常通用的消息,表明某种未指定的驱动程序或硬件问题。我会在您收到报告后向您提供进一步的说明。我希望尽快收到您的回复.Regards,Diego S. 以上来自于谷歌翻译 以下为原文 Hello ratchakan, Thank you for posting in our Intel ® Community. I understand that you are facing the “This device cannot start. (Code 10)” error, let us do our best to assist you. In order to determine the status of your system please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the “Attach” option on the bottom right-hand corner of the response box. The error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers or by a damaged component. A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. A Code 10 error can be a very generic message indicating some kind of unspecified driver or hardware problem. I will provide you with further instructions once that I have your report. I hope to hear from you soon. Regards, Diego S. |
回去。十月更新这样做。
我安装旧版Windows和wifi工作。 我禁用了更新。 并等待微软修复此问题 以上来自于谷歌翻译 以下为原文 Go back.the October update do this. I install the older version of Windows and the wifi work. I disable the updates. And wait for Microsoft repair this |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-15 09:50 , Processed in 4.788608 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
458
