电子发烧友论坛|
第二次尝试发布这个消息,不确定我的第一个发生了什么,因为它没有出现在论坛上。我有一个劳拉湾项目成功使用18LF46K22使用MCC和库版本1.45。系统时钟是使用内部振荡器,我有一个32.768 kHz晶体DRI。在第二个振荡器上设置定时器1。当我尝试使用一个新的库(155,165.1和165.2)时,我会抱怨一个错误,我需要连接T1CKI引脚。如果我确实需要并连接PIN,它就要求它正确地抱怨次级振荡器所需要的SOSCO引脚。我用一个定时器1和二次振荡器创建了一个裸露的项目,我也遇到了同样的问题。马克在新图书馆工作。
以上来自于百度翻译 以下为原文 Second attempt at posting this message, not sure what happened to my first one as it didn't show up in the forum. I have a Lorawan project which works successfully using a 18LF46K22 using MCC and Library version 1.45 The system clock is using the internal oscillator and I have a 32.768khz crystal driving Timer 1 on the secondary oscillator. When I try and use a newer library (155, 165.1 and 165.2) I get an error complaining that I need to connect the T1CKI pin. As per the datasheet the T1CKI pin is not used when the secondary oscillator is used. If I do oblige and connect the pin it asks for it then correctly complains about the SOSCO pin which is needed for the secondary oscillator. I have created a bare bones project with just the Timer 1 and secondary oscillator and I get the same problem. Has anybody else managed to get the secondary oscillator working on the newer libraries. Mark |
1个回答
嗨,马克,你的报道是对的。这是一个错误。当选择二次振荡器时。MCC不应强制选择T1CKIIT,将考虑修复。谢谢。
以上来自于百度翻译 以下为原文 Hi Mark, What you have reported is correct. It's a bug. When the Secondary oscillator is selected. MCC should not force to select T1CKI It will be taken into consideration for a fix. Thank you |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1097浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 07:27 , Processed in 0.745277 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1866
