我在3000系列以及4000系列范围内遇到了一个问题。
当我们在NORMAL模式下调整时基设置(水平****)时,波形的电压很好。 一旦我们改为高分辨率模式,我们调整时基设置,波形的电压降低与时基的增加成比例。 这是大多数范围的错误吗? 以上来自于谷歌翻译 以下为原文 There is an issue I faced in 3000 series as well as 4000 series scope. When we adjust the time-base setting in NORMAL mode, (horizontal ****), the waveform’s voltage is fine. Once we changed to HIGH-RESOLUTION mode, and we adjust the time-base setting, the waveform’s voltage decrease proportional to the increase of the time-base. Is it a bug on most of the scopes? |
1个回答
你没有说出你的信号,时间范围或其他任何事情,但我想我知道发生了什么。
高分辨率模式是一种“平均”模式。 它使用boxcar平均方法来降低显示信号的噪声。 它还在使用时减少了示波器的带宽。 它主要用于查看低频或直流信号。 当您更改时基时,采样率可能会发生变化,而较低的采样率也会降低带宽。 除非您正在查看低带宽信号或DC,否则不应使用高分辨率模式。 人 以上来自于谷歌翻译 以下为原文 You don't say anything about your signal, time ranges, or much of anything else, but I think I know what's happening. High-Resolution mode is an "averaging" mode. It uses a boxcar averaging method to reduce the noise on a displayed signal. It also reduces the bandwidth of the scope when in use. It is really intended for looking at low-frequency or DC signals. As you change the timebase, the sample rate can change, and lower sample rate also reduces the bandwidth. Unless you are looking at low bandwidth signals, or DC, you shouldn't use High-Res mode. Al |
只有小组成员才能发言,加入小组>>
1272 浏览 0 评论
2371 浏览 1 评论
2187 浏览 1 评论
2061 浏览 5 评论
2944 浏览 3 评论
1091浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
746浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
912浏览 0评论
1276浏览 0评论
GMT+8, 2024-12-20 03:46 , Processed in 1.561598 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
