电子发烧友论坛|
我遇到了串行事件处理程序的问题(eventDisposed工作正常)但是eventDataRecived没有执行但是占用50%的CPU时间,然后在关闭串口时锁定VEE。
(所有在VS c#中工作正常)我在我的开发机器上安装了.NET framework v2和v4,并且想知道是否使用v4可能是答案,.Net Assembly References对话框会选择v2的位置。 如果我浏览到v4.0.30319目录“System.dll”错误,因为它不是有效的.NET程序集? 有没有办法让VEE使用v4框架? Win7 Pro下的VEE 9.3.15。 以上来自于谷歌翻译 以下为原文 I'm having problems with the serial event handler (eventDisposed works fine) but eventDataRecived does not execute but eats 50% CPU time and then locks VEE if I close the serial port. (all works fine in VS c#) I have .NET framework v2 and v4 installed on my development machine and was wondering if using v4 might be the answer, the .Net Assembly References dialog picks up the location of the v2. If I browse to the v4.0.30319 directory "System.dll" errors as not being an valid .NET assembly ? Is there a way to get VEE to use the v4 framework ? VEE 9.3.15 under Win7 Pro. |
4个回答
我是否正确地断定VEE 9.3仅适用于安装盘附带的已安装的.NET SP3.5?
以上来自于谷歌翻译 以下为原文 Am I right in concluding that VEE 9.3 only works with the installed .NET SP3.5 included with the install disk ? |
保罗,将以下内容添加到C: Program Files(x86) Agilent VEE Pro 9.3中的Vee.exe.config中。请参阅附件。 我自己没试过,但我告诉它有效。 在VEE反射器上拾取它,这是获得帮助的最快方式。 要订阅,请发送电子邮件至:“vrf-request@general.lists.agilent.com”,邮件正文中包含单词subscribe(仅限长签名和纯文本)。 祝你好运,比尔 以上来自于谷歌翻译 以下为原文 Paul, Add the following to Vee.exe.config in C:Program Files (x86)AgilentVEE Pro 9.3 See attached. I haven't tried this myself, but I'm told it works. Picked it up on the VEE reflector, which is the fastest way to get help. To subscribe send an email to: "vrf-request@general.lists.agilent.com" with the word subscribe in the message body (no long signatures and plain text only). Good luck, -Bill 附件
derek88 发表于 2018-10-15 12:54 谢谢比尔,我刚刚通过浏览发现它并且正在发布“使用.Net4.0”作为所需的搜索。 刚刚使用了配置并且它确实有效,遗憾的是它不会影响我对我的串口事件处理程序的问题。 感谢您解决这个问题。 干杯保罗 以上来自于谷歌翻译 以下为原文 Thanks Bill, I just found it by wading through and was going post "using .Net4.0 " as being the search needed. Just used the config and it does work, unfortunately doesn't affect the problem I'm having with my serial port event handler. Thanks for the solution to this one though. Cheers Paul |
zyh34997 发表于 2018-10-15 13:10 看看升级到VEE 9.32是否有帮助。 该版本中有一些Windows 7兼容性更改。 -法案 以上来自于谷歌翻译 以下为原文 See if upgrading to VEE 9.32 helps. There were some Windows 7 compatibility changes in that release. -Bill |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 20:36 , Processed in 0.954902 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1238
