那个高手给看看,keil无法编译,谢谢了。
错误提示如下: *** Using Compiler 'V5.05 update 2 (build 169)', folder: 'C:Keil_v5ARMARMCCBin' Rebuild target 'STM32L476RG_NUCLEO' compiling system_stm32l4xx.c... Error: C9511E: Product definition file was not found. The following paths were searched: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 2 (build 169) Tool: ArmCC [4d0f38] compiling stm32l4xx_nucleo.c... Error: C9511E: Product definition file was not found. The following paths were searched: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 2 (build 169) Tool: ArmCC [4d0f38] compiling main.c... Error: C9511E: Product definition file was not found. The following paths were searched: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 2 (build 169) Tool: ArmCC [4d0f38] compiling stm32l4xx_it.c... Error: C9511E: Product definition file was not found. The following paths were searched: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 2 (build 169) Tool: ArmCC [4d0f38] compiling stm32l4xx_hal_gpio.c... Error: C9511E: Product definition file was not found. The following paths were searched: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 2 (build 169) Tool: ArmCC [4d0f38] compiling stm32l4xx_hal.c... Error: C9511E: Product definition file was not found. The following paths were searched: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 2 (build 169) Tool: ArmCC [4d0f38] compiling stm32l4xx_hal_cortex.c... Error: C9511E: Product definition file was not found. The following paths were searched: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 2 (build 169) Tool: ArmCC [4d0f38] compiling stm32l4xx_hal_pwr_ex.c... Error: C9511E: Product definition file was not found. The following paths were searched: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 2 (build 169) Tool: ArmCC [4d0f38] compiling stm32l4xx_hal_rcc_ex.c... Error: C9511E: Product definition file was not found. The following paths were searched: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 2 (build 169) Tool: ArmCC [4d0f38] compiling stm32l4xx_hal_pwr.c... Error: C9511E: Product definition file was not found. The following paths were searched: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 2 (build 169) Tool: ArmCC [4d0f38] compiling stm32l4xx_hal_rcc.c... Error: C9511E: Product definition file was not found. The following paths were searched: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap Error: C9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap Product: unknown Component: ARM Compiler 5.05 update 2 (build 169) Tool: ArmCC [4d0f38] assembling startup_stm32l476xx.s... startup_stm32l476xx.s: Error: A9511E: Product definition file was not found. The following paths were searched: startup_stm32l476xx.s: - C:Keil_v5ARMARMCCBinmdk_cm_pro.elmap startup_stm32l476xx.s: - C:Keil_v5ARMARMCCBin....swmappingsmdk_cm_pro.elmap startup_stm32l476xx.s: - C:Keil_v5ARMARMCCBin......swmappingsmdk_cm_pro.elmap startup_stm32l476xx.s: - C:Keil_v5ARMARMCCBin..swmappingsmdk_cm_pro.elmap startup_stm32l476xx.s: startup_stm32l476xx.s: Error: A9545E: Info key CT.ProductName could not be found in product definition C:Keil_v5ARMARMCCswmappingsarmcompiler.elmap startup_stm32l476xx.s: Product: unknown startup_stm32l476xx.s: Component: ARM Compiler 5.05 update 2 (build 169) startup_stm32l476xx.s: Tool: ArmAsm [4d0f2f] "STM32L476RG_NUCLEOSTM32L476RG_NUCLEO.axf" - 2 Error(s), 0 Warning(s). Target not created. Build Time Elapsed: 00:00:01 |
9个回答
自己顶顶,不是版本问题把,keil v5.15应该支持stm32L4的呀
看最后一句产品破解不成功
是那句,Target not created. 还是:Build Time Elapsed: 00:00:01 这两句表达的意思确实不知所云 |
高手:还有就是您那个功耗帖子,咋样建cube工程,可以指个路吗,那个帖子或文档有说明?先谢谢了。。。http://www.stmcu.org/module/foru ... B%E5%8A%9F%E8%80%97 |
目标没创建成功,这是结果,不是报错 |
检查一下#include关系,不要错误引用了.
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 09:06 , Processed in 1.244019 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
667
