电子发烧友论坛|
使用E5071C VNA和相关的SOLT校准时遇到问题。
我所看到的是奇怪的,我相信并迫使我派遣一个单位进行维修无济于事。 在端口1和端口上使用相同的标准执行标准的2端口校准。 2.当在端口2上测量开路或短路时,我看到S22曲线上0dB的急剧偏差; 视频中的标准纹波和过去的8GHz至20GHz显示在端口2上测量的负载也将显示频率较高的响应,在频谱的高端超过10dB。 它是如此糟糕,负载看起来比短/开放更糟糕。 我知道显示的数据是原始的,校准似乎正在纠正它。 我比较了测量一个有损电缆之间的租金(没有显示这个现象)VNA和“坏”VNA和相关性非常好。 我的直觉告诉我,2号港口的匹配非常差,这可以解释围绕史密斯圆图的“远远”阻抗。 使用租赁VNA测量每个港口并未在比赛中显示出任何明显的差异。 知道发生了什么事吗? 我被告知VNA的维修是换掉端口2上的NMD连接器。我不认为维修设施已经意识到这个问题,只是发回了一个符合规格的装置。 提前致谢 以上来自于谷歌翻译 以下为原文 Having trouble with an E5071C VNA and associated SOLT calibration. What I am seeing is odd I believe and has forced me to send a unit out for repair to no avail. Performing a standard 2 port calibration, using the same standards on ports 1 & 2. When measuring on port 2 with either the open or short, I see a drastic deviation from 0dB on the S22 plot; with the standard ripple in view and past 8GHz up to 20GHz showing <-20dB. Port 1 shows a nearly flat line at 0dB as expected. A load measured on port 2 will also show poor response higher in frequency, exceeding 10dB on the high end of the spectrum. It is so bad, that the load looks worse RAW than the short/ open. I understand the data being shown is raw, and the calibration appears to be correcting for it. I have compared measuring a lossy cable between a rental (does not show this phenomenon) VNA and the "bad" VNA and the correlation is excellent. My gut told me that port 2 would have a very poor match which would explain this "far out" impedance wrapping around the Smith Chart. Measuring each port with a rental VNA did not show any appreciable difference in the match. Any idea what is going on? I was told the repair to the VNA was to swap out the NMD connector on port 2. I don't think the repair facility was made aware of the problem and just sent back a unit that was in spec. Thanks in advance |
1个回答
听起来真的如此,NMD测试端口连接器有一些问题。
尝试截取问题的截图。 当您发送VNA进行修复时,请使用VNA打印出这些屏幕截图。 然后服务人员可以看到问题,他们肯定会修复它。 否则可能会像你说的那样兴奋地发生,他们放在测试台上,所有这些都符合规范。 图奥马斯 以上来自于谷歌翻译 以下为原文 Sounds really so, that NMD test port connector has some issues. Try to take screenshots how the problem looks like. When you sending the VNA to repair, print out those screenshots with the VNA. Then service personel can see the problem and they will fix it for sure. Otherwise can happen excatly as you told, that they put in on the test bench and all goes in-spec. Tuomas |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-2 03:02 , Processed in 0.746238 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1650
