电子发烧友论坛|
你好,我有一个1680A的Adlink M-815G主板。
它运行Win XP SP2和LA软件版本3.67没有任何问题。 我想将它升级到Win XP SP3,这样我就可以运行更高版本的LA软件(5.70)。 不幸的是,当我尝试安装SP3补丁时,出现了问题,分析仪将不再启动。 然后我安装了一个新的Win XP SP3副本,分析仪启动到Windows,但内部LCD显示器没有激活,我可以使用分析仪的唯一方法是使用外部显示器。 最后,我从Keysight FTP站点(01680-14106)下载了恢复CD映像文件,虽然它们似乎已经恢复了硬盘驱动器,但一旦恢复完成,分析器只能获得初始磁盘检查例程,然后 停滞在“准备启动Windows”消息。 我重复了这个过程,重新下载了恢复映像但得到了相同的结果。 顺便说一句,这似乎与他在2009年7月24日在“示波器/一般用法”论坛上关于他自己的1680A恢复过程的帖子中描述的“tonykara”相同。 问题:1)我是否遗漏了CD恢复过程中的内容? 我按照“书”做了一切,但stil无法使分析仪正常启动。 2)有没有办法启用内部LCD,以便我可以使用我的OEM Windows XP SP3安装盘并从那里开始? 我想如果我能将内置LCD作为主要显示器,我可以安装LA软件并完成。 谢谢,新年快乐! 斯坦 以上来自于谷歌翻译 以下为原文 Hello, I have a 1680A with the Adlink M-815G motherboard. It was running Win XP SP2 and LA software version 3.67 with no problems. I wanted to upgrade it to Win XP SP3 so I could run a later version of the LA software (5.70). Unfortunately, when I tried to install the SP3 patch, something went wrong and the analyzer would no longer boot. I then installed a fresh copy of Win XP SP3, and the analyzer booted up fine into Windows, but the internal LCD display was not active, and the only way I could use the analyzer was with an external display. Finally, I downloaded the restore CD image files from the Keysight FTP site (01680-14106), and although they appeared to have restored the hard drive, once the restore was completed the analyzer got only as far as the initial disk check routine, then stalled at "Getting ready to start Windows" message. I repeated the process with fresh downloads of the restore images but got the same result. BTW, this appears to be the same problem as "tonykara" described in his posting on 7/24/09 in the "Oscilloscopes/General Usage" forum about his own 1680A restore process. Questions: 1) Am I missing something with the CD restore process? I did everythhing "by the book" but stil can't get the analyzer to boot properly. 2) Is there a way to enable the internal LCD so I can use my OEM Windows XP SP3 install disk and go from there? I think if I could get the internal LCD to be the primary display, I could just install the LA software and be done. Thanks and Happy New Year! Stan |
9个回答
您可能遇到某种硬件问题。
如果SP3更新无法正确安装,并且CD恢复过程不起作用,则两次,则会发生其他事情。 内部显示器需要一些特殊的驱动程序,这些驱动程序仅作为恢复映像的一部分提供,因此您唯一的选择可能是将其与外部显示器一起使用。 问题可能与显示有关。 这台分析仪很久以前就停产了,并在3年多前“失去了支持”,所以真的没有什么可以做的了。 人 以上来自于谷歌翻译 以下为原文 You may have some sort of HW problem. If the SP3 update wouldn't properly install, and the CD restore process doesn't work, twice, then there's something else going on. The internal display needs some special drivers that are only available as part of the restore image, so your only choice may be to use it with an external display. The problem may be related to the display. This analyzer was discontinued a long time ago and went "out of support" more than 3 years ago, so there's really nothing more that can be done. Al |
nvywyerwer 发表于 2018-10-4 18:20 嗨Al,谢谢你的回复! 分析仪实际上确实接受了完整的Win XP SP3更新(来自Microsoft OEM安装CD),但我不想使用它,因为它缺少LCD驱动程序。 原来的Win XP SP2操作系统(1680A附带的硬盘驱动器上的操作系统)只有SP3补丁无效。 我相信如果我能让内部LCD显示器工作,我的1680A硬件将运行SP3。 据推测,LCD驱动程序将位于从映像文件恢复的硬盘驱动器上,我当然可以从1680A中删除该HD并使用另一台PC查看所有文件。 不幸的是,我不确定如何识别特定的内部LCD驱动程序文件,但如果可以,我希望我可以将它们安装在具有OEM Win XP SP3安装的驱动器中并从那里开始。 这听起来像是一种合理的方法吗? 此致,斯坦 以上来自于谷歌翻译 以下为原文 Hi Al, Thanks for the reply! The analyzer actually did accept the full Win XP SP3 update (from the Microsoft OEM install CD), but I didn't want to use it because it was missing the LCD drivers. It was only the SP3 patch to the original Win XP SP2 OS (the one on the hard drive that came with the 1680A) that didn't work. I believe that my 1680A hardware will run SP3 fine if I could just get the internal LCD display to work. Presumably, the LCD drivers will be on the hard drive that was restored from the image files, and I can certainly remove that HD from the 1680A and look at all the files using another PC. Unfortunately, I'm not sure how I would identify the specific internal LCD driver files, but if I could, I would expect that I could install them in the drive that has the OEM Win XP SP3 installation and go from there. Does this sound like a reasonable approach? Regards, Stan |
daichuangs 发表于 2018-10-4 18:38 我试图看看是否可以将驱动程序与完整的CD映像分开。 但是,可能存在一些许可限制。 我没有你会在“恢复的”硬盘上识别出那些驱动程序。 人 以上来自于谷歌翻译 以下为原文 I'm trying to see if it's possible to get the drivers separately from the full CD images. There may be some licensing constraints, though. I have no dea ho you would identify those drivers on the 'recovered' hard drive. Al |
daichuangs 发表于 2018-10-4 18:38 我正在阅读你的帖子,想看看我是否可以提供帮助。 我很擅长电脑。 您是否认为使用外接显示器,您可以进入1680A的设备管理器,看看哪些设备显示为缺少驱动程序? 然后,在那里,单击Details选项卡,然后在下拉菜单中,单击Device Instance Id。 这是一个网站的链接,可以更好地解释图片的说明。 http://www.makeuseof.com/tag/how-to-find-unknown-device-drivers-by-their-vendor-device-id/ 以上来自于谷歌翻译 以下为原文 I was reading your post and wanted to see if I could help. I'm pretty good with computers. Do you think using an external monitor, you could go into device manager on your 1680A to see what device shows up as missing drivers? Then once in there, click on the Details tab and then in the drop down menu, click Device Instance Id. Here's a link to a website that explains the instructions a bit better with pictures. http://www.makeuseof.com/tag/how-to-find-unknown-device-drivers-by-their-vendor-device-id/ |
gwerwfe 发表于 2018-10-4 18:54 通常,驱动程序安装在 system32 drivers中,inf文件存储在 inf(这是一个隐藏目录)我相信。 默认情况下,通常是C: Windows 。 自从我玩Windows XP以来已经有一段时间了。 我在想如果你能获得供应商和设备ID,我们可以在 inf目录中弄清楚你需要什么INF文件,然后用它来找出你需要从 system32 drivers目录驱动的驱动程序。 您还可以尝试从旧驱动器上复制整个 inf目录和 system32 drivers目录,并将其放在CD或拇指驱动器上(无论您支持什么范围)。 然后在设备管理器中,转到无法正常工作的设备,单击更新驱动程序,将其指向CD thumb驱动器的根目录,然后告诉windows搜索子目录。 我想它会发现inf文件和正确的驱动程序.... 以上来自于谷歌翻译 以下为原文 Generally, the drivers are installed in system32drivers and the inf files are stored in inf (which is a hidden directory) I do believe. , by default, is usually C:Windows. Been awhile since I played with Windows XP. I was thinking if you could get the vendor and device IDs, we could figure out what INF file you needed in the inf directory and use that to figure out what drivers you need from system32drivers dir. You could also try copying the whole inf directory and system32drivers directory off the old drive and putting it on a CD or thumb drive (whatever you scope supports). Then in device manager, go to the device that isn't working properly, click on Update driver, point it to the root directory of the CD thumb drive, and tell windows to search subdirectories. I'd like to think it'd discover the inf file and the proper drivers.... |
gwerwfe 发表于 2018-10-4 19:09 我不知道这些是否会有所帮助。 我从01680-14106 ISO中提取它们。 它们位于Program Files Asiliant LCD目录中,它们是驱动程序。 以上来自于谷歌翻译 以下为原文 I don't know if these will help or not. I extracted them from the 01680-14106 ISOs. They were in the Program FilesAsiliantLCD directory and they're drivers. 附件
gwerwfe 发表于 2018-10-4 19:16 感谢您的所有好建议和辛勤工作! 一旦我将Win XP SP3重新安装到1680A上,我就会试试这些驱动程序并报告我的发现。 此致,斯坦 以上来自于谷歌翻译 以下为原文 Thanks for all your good advice and hard work! As soon as I reinstall Win XP SP3 onto the 1680A I'll give those drivers a try and report back my findings. Regards, Stan |
gwerwfe 发表于 2018-10-4 19:16 好消息! 我能够让一切正常,但不是我原先以为的方式。 我首先安装了Win XP SP3的OEM副本,然后使用LCD驱动程序启用内部显示。 但是,当我尝试安装LA软件时,它抱怨说虽然它识别了安捷伦硬件,但磁盘映像无效,我需要从安捷伦获得更换硬盘。 然后我使用安捷伦恢复CD从头开始恢复硬盘。 当我到达1680A在之前的尝试之后总是“冻结”的同一点时,我发现发生的事情是1680A切换到外部VGA端口并等待我的输入完成安装。 偶然的是,这次我碰巧有一个显示器连接到VGA端口并且看到了这个,但之前从未这样做过,所以在过去它一直只是看起来1680A已经冻结了。 当我在外部显示器上完成设置后,1680A重新启动,“找到”新的LCD硬件,并从硬盘驱动器安装了LCD驱动程序。 毕竟,我安装了Win XP SP3补丁,安装了LA 5.70软件,一切都很好! 再次感谢大家的帮助和建议! 以上来自于谷歌翻译 以下为原文 Good news! I was able to get everything working, but not the way I had originally thought I would. I started by installing an OEM copy of Win XP SP3, and then used the LCD drivers to enable the internal display. However, when I tried to install the LA software, it complained that although it recognized the Agilent hardware, the disk image was not valid and I needed to get a replacement hard drive from Agilent. Then I used the Agilent restore CDs to restore the hard drive from scratch. When I got to the same point where the 1680A had always "frozen" after my previous attempts, I found that what was happening was that the 1680A had switched over to the external VGA port and was waiting for my input to finalize the installation. Serendipitously, I just happened to have a monitor attached to the VGA port this time and saw this, but had never done this before, so in the past it had always just appeared that the 1680A had frozen. When I finished the setup on the external monitor, the 1680A rebooted, "found" the new LCD hardware, and installed the LCD driver from the hard drive. After all that, I installed the Win XP SP3 patch, installed the LA 5.70 software, and all is well! Thanks again to everyone for their help and suggestions! |
真高兴你做到了! 恭喜!!! 以上来自于谷歌翻译 以下为原文 Glad you got it working! Congrats!!! |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 14:51 , Processed in 0.882798 second(s), Total 58, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1349
