我们有3张NVIDIA Tesla M10显卡。
三个Cisco UCSC-C240-M4S主机中的每一个都有一张卡。 我们正在使用Horizon 7.1。 我有一个有5个VM的池。 他们正在使用m10-2q配置文件。 我无法启动父母图像。 我收到以下错误: 父资源池中可用的图形资源量不足以进行操作。 我尝试将父映像上的配置文件更改为其他几个配置文件,但仍然无法启动VM并获得相同的错误消息。 另外要注意。 每当我刷新或重新组合这个池时,VM都难以启动。 在最后一次启动第三次之前,它们会在相同的消息中出错。 我不确定这是否需要我要求VMware或NVIDIA,所以我想我会从这里开始。 以上来自于谷歌翻译 以下为原文 We have 3 NVIDIA Tesla M10 cards. One card in each of three Cisco UCSC-C240-M4S hosts. We are using Horizon 7.1. I have one pool with 5 VM's in it. They are using the m10-2q profile. I am unable to power on my parent image. I get the following error: The amount of graphics resource available in the parent resource pool is insufficient for the operation. I have tried changing the profile on the parent image to several other profiles but still unable to power on the VM and get same error message. Also to note. Whenever I refresh or recompose this pool the VM's struggle to startup. They error out with the same message a couple time before finally booting on the third. I'm not sure if this is something I need to be asking VMware or NVIDIA so I figured I would start here. |
4个回答
嗨,
您应该在ESX中更改合并策略: “要提高虚拟机整合率,可以将ESXi主机设置为使用整合模式。 编辑ESXi主机上的/ etc / vmware / configfile并添加以下条目: vGPU.consolidation =“true” 默认情况下,ESXi主机将虚拟机分配给已分配最少虚拟机的物理GPU。 这称为性能模式。 如果您希望ESXi主机将虚拟机分配到同一物理GPU,直到在将虚拟机放置到下一个物理GPU上之前达到最大虚拟机数量,则可以使用合并模式。 以上来自于谷歌翻译 以下为原文 Hi, you should change the consolidation policy witihin ESX: „To improve virtual machine consolidation ratios, you can set the ESXi host to use consolidation mode. Edit the /etc/vmware/config file on the ESXi host and add the following entry: vGPU.consolidation = "true" By default, the ESXi host assigns virtual machines to the physical GPU with the fewest virtual machines already assigned. This is called performance mode. If you would rather have the ESXi host assign virtual machines to the same physical GPU until the maximum number of virtual machines is reached before placing virtual machines on the next physical GPU, you can use consolidation mode. |
我实际上发现了根本问题。
每个主机图形配置都设置为Shared而不是Shared Direct。 使此开关解决了问题。 谢谢你的回复 - 我也会使用这个建议。 以上来自于谷歌翻译 以下为原文 I actually discovered the root issue. Each host graphics configuration was set to Shared instead of Shared Direct. Making this switch resolved the issue. Thanks for reply - I will use this suggestion too. |
嗨 - 我得到相同的“可用的图形资源量”错误。
我刚刚将一些ESXi主机升级到Esxi 6.0 Patch 5(即rev 5572656)。我所有的K2机器都无法启动。 我正在运行Vcenter 6.0.0 3018524.因此,我没有看到这些选项直接共享,因为我不在vCenter 6.5上。 有什么想法吗 ? 以上来自于谷歌翻译 以下为原文 Hi - I am getting the same "amount of Graphics resource available" error. I just upgraded some ESXi hosts to Esxi 6.0 Patch 5 ( i.e. rev 5572656 ).. All my K2 machines will not turn on. I am running Vcenter 6.0.0 3018524. Thus i do not see those options for shared direct as im not on vCenter 6.5. Any thoughts ? |
这似乎是VMWare补丁的一个问题。
https://recommender.vmware.com/solution/SOL-14076 请联系VMWare获取解决方案。 以上来自于谷歌翻译 以下为原文 THis seems to be an issue with VMWare patch. https://recommender.vmware.com/solution/SOL-14076 Please contact VMWare for a solution. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2836 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3227 浏览 4 评论
GMT+8, 2024-4-28 03:29 , Processed in 0.564814 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
