电子发烧友论坛|
我们的2通道DS06012A上的一个通道已经损坏 - 它仍然会拾取一些信号,但它会严重衰减。
另一个频道仍然运作良好,并定期使用。 但是,我似乎无法获得执行用户校准的范围,我认为这是因为它没有在第一个通道上检测到信号。 有没有办法解决? 以上来自于谷歌翻译 以下为原文 One of the channels on our 2 channel DS06012A has been damaged - it still picks up some signal but it is heavily attenuated. The other channel still works well and is used regularly. However, I can't seem to get the scope to perform a user calibration, I assume this is because it is not detecting a signal on the first channel. Is there any way around this? |
1个回答
后面板上有一个cal保护开关...你需要用BNC T将触发器连接到chs 1和2上,参考维修指南:6000A服务指南,最终http://literature.cdn.keysight。
com / litweb / pdf / 54684-97029.pdf它可能无法通过自我校准,因此需要在Keysight服务中心进行维修。 如果它自动失败,您可能会发现某些功能被禁用,例如自动缩放...您可能还会发现获得新范围而不是修复它更具成本效益。 www.Keysight.com/find/3000TX-Series您可以在此处查看保修状态:www.Keysight.com/find/warranty 以上来自于谷歌翻译 以下为原文 there is a cal protect switch on the rear panel... you will need to hook the trig out to chs 1 and 2 with a BNC T refer to service guide: 6000A Service Guide, Final http://literature.cdn.keysight.com/litweb/pdf/54684-97029.pdf It probably will not pass self cal, and thus it will need to be repaired at a Keysight service center. if it fails self cal, you may find that certain features are disabled, like autoscale... You may also find it more cost effective to get a new scope rather than have it repaired. Www.Keysight.com/find/3000TX-Series You can check the warranty status here: www.Keysight.com/find/warranty |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 16:52 , Processed in 0.701094 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1001
