电子发烧友论坛|
你好,
我正在安装2台新的HP DL380 Gen9服务器,每台服务器都配有TESLA M60卡。 我安装了XenServer 7.2(包含所有当前的补丁)。 从我将这些M60卡从COMPUTE切换到GRAPHICS模式的那一刻起,FANS就会达到100%的速度并产生很多噪音。 我已经安装了NVIDIA GRID Manager 5.1版。 还有XenServer平台上的HP SNMP Agent,但每次重启后,在XenServer Hypervisor的启动阶段突然间,风扇再次以100%的速度运行。 在BIOS中,“最佳冷却”功能设置为默认值 我已将BIOS固件更新到最新版本P89 v2.52(10/25/2017),但仍然没有运气,在每次重启后,在XS启动期间,风扇以最大速度吹出一大堆 噪声。 有任何经验建议可以改善吗? 这是HP还是XenServer或Nvidia问题? 换句话说,联系谁来创建支持票。 谢谢, 克里斯马雷尔 以上来自于谷歌翻译 以下为原文 Hello, I'm in the process of installing 2 new HP DL380 Gen9 servers each equipped with a TESLA M60-card. I have installed XenServer 7.2 (with all the current patches). And from the moment I have switched these M60-cards from COMPUTE to GRAPHICS mode the FANS go to 100% of their speed and making a lot of noise. I have already installed the NVIDIA GRID Manager Version 5.1. And also the HP SNMP Agents on the XenServer platform, but after each reboot, during the startup-phase of the XenServer Hypervisor at a sudden moment the fans are going to 100% speed again. In the BIOS the 'optimal cooling' feature is set to the default I have updated the BIOS-firmware to the last version P89 v2.52 (10/25/2017), but still no luck, after each reboot, during the startup of XS the fans are blowing at their maximum speed an making a lot of noise. Any suggestions of experiences to improve this ? Is this an HP or XenServer or Nvidia-issue? In other words who to contact to create a support-ticket. Thanks, Chris Marreel |
8个回答
嗨......你确定电缆是否能阻挡气流?
电源的功率是多少? 在带有1100 W电源的Dell R730服务器上,我看不到这样的情况。 你有很多其他外围设备可能会产生大量额外的热量吗? 以上来自于谷歌翻译 以下为原文 Hi... Are you sure the cables are such that they are not obstructing the airflow? What is the wattage of your power supplies? I don't see anything like this on Dell R730 servers with 1100 W power supplies. Do you have a lot of other peripherals in there that may be contributing to a lot of extra heat? |
你好,
首先,我想知道你在哪里买了M60主板? 这些是直接来自惠普还是这些通用主板? 我认为这些是通用主板,惠普在其主板上有特定的vbios,所以请联系惠普。 只要该板被nvidia-smi识别并且GPU在空闲时没有100%GPU负载运行,我不明白为什么这应该是Nvidia问题。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hello, first of all I would like to know where you bought the M60 boards? Are these directly from HP or are these generic boards? I would assume these are generic boards and HP has a specific vbios on their boards so please contact HP. As long as the board is recognized with nvidia-smi and the GPU is not running on 100% GPU load in idle I don't see why this should be a Nvidia issue. Regards Simon |
托比亚斯和西蒙你好,
此M60卡是此DL380 Gen9服务器中唯一的额外卡。 如果我们测试几次重新启动,那么在XenServer 7.2的启动阶段,风扇每次都会在同一时刻旋转到100%。 所以我的结论是:它与温度无关,只有一些“逻辑”认为风扇应该达到100%的速度(噪音是恼人的副作用)。 在该服务器中有2x 1400W电源,两者都运行“冗余”,目前仅提供409W。 因此,这些M60板的电源是正确的。 M60卡由惠普提供,nvidia-smi正在识别主板,目前我已经拥有了第一台使用M60卡的Win10工作站,所以一切运行正常,只有风扇速度和生成 噪音是一个问题。 如果没有其他想法,我会在HPE支持上记录一张票。 谢谢和问候, 克里斯 以上来自于谷歌翻译 以下为原文 Hello Tobias and Simon, This M60-card is the only extra card in this DL380 Gen9 server. And the fans are spinning up to 100% during the startup-phase of the XenServer 7.2 each time at exact the same moment if we test a few reboots. So my conclusion : it has nothing to do with temperature, only with some 'logic' that is thinking the fans should go to 100% speed (with the noise as annoying side effect). In that server there are 2x 1400W power supply's, both running 'redundant' and at the moment only delivering 409W. So the power supply's are correct for these M60-boards. The M60-cards are delivered by HP, and the nvidia-smi is recognizing the board, and at the moment I already have my first Win10-station using the M60-card, so everything is running fine, only the fan speed and the generated noise is an issue. If there are no other thoughts, I will log a ticket at HPE Support for this. Thanks and greetings, Chris |
你好
我曾经在各种硬件上看过几次。 如果您还没有这样做,可以记下当前的BIOS配置(如果有任何特殊配置),然后将BIOS重置为出厂默认设置。 重置后,检查所有组件的所有相关“功率/性能”和“冷却”策略,它们都应设置为“平衡”。 尝试一下,看看它是否有帮助,让我们知道你是如何进行的...... 问候 本 以上来自于谷歌翻译 以下为原文 Hi I've seen this before a few times on various hardware. If you haven't done so already, can you make a note of the current BIOS configuration (in case there is anything special configured) and then reset the BIOS back to factory default. Once reset, check all the associated "Power / Performance" and "Cooling" policies for all components, they should all be set to something like "Balanced". Give that a try and see if it helps, let us know how you get on ... Regards Ben |
你好,
我进一步调查了这一点。 我的设置工作正常,但我暂时停止了此环境,并将XenServer主机置于维护中。 我删除了NVIDIA Grid Manager(使用的命令:rpm -e NVIDIA-vGPU-xenserver-7.2-384.99.x86_64 ),并重新启动XenServer主机以完成卸载。 在重启期间,我注意到FAN速度保持在正常水平。 我查了一下,目前仍然是最新版本的NVIDIA GRID Manager(2017年11月10日第5.1版)。 所以我将这个NVIDIA Grid Manager重新安装回XenServer主机。 在安装了NVIDIA Grid Manager之后的REBOOT之后,我注意到在Xenserver的启动阶段,FAN SPEED达到了100%。 它位于XenServer 7.2操作系统启动的中间位置,所以可能在GRID Manager正在进行ititialising时,您会听到35-39%的FAN SPEED增加到100%。 所以目前我认为我需要联系NVIDIA支持部门以获得有关此问题的帮助。 任何输入都是欢迎的。 附: 我如何联系NVIDIA支持? 问候, 克里斯马勒 以上来自于谷歌翻译 以下为原文 Hello, I have investigated this further. My setup was working fine, but I have temporary stopped this environment, and placed the XenServer host in Maintenance. I have removed the NVIDIA Grid Manager (command used: rpm -e NVIDIA-vGPU-xenserver-7.2-384.99.x86_64 ), and rebooted the XenServer-host to finalize the de-installation. During this reboot, I noticed the FAN-speed stays at a normal level. I checked and this is at the moment still the latest version of the NVIDIA GRID Manager (Version 5.1 of 10 November 2017). So I re-installed this NVIDIA Grid Manager back onto the XenServer host. And after the REBOOT after this NVIDIA Grid Manager is installed I noticed that the FAN SPEED went to 100% during the start-up-phase of the Xenserver. It's somewhere halfway the startup of the XenServer 7.2 OS, so probably at the moment the GRID Manager is ititialising you hear the FAN SPEED of 35-39% increasing to 100%. So at the moment I think I will need to contact NVIDIA Support for assistance in this issue. Any input is welcom. P.S. How can I contact NVIDIA Support ? Greetings, Chris MARREEL |
嗨cmarreel,
您是否与HP支持部门联系? 我仍然没有看到Nvidia如何在这里提供帮助。 如果这对我们的vGPU管理器来说是一个普遍的问题,我会同意联系Nvidia,但由于这似乎是针对您的硬件的,因此OEM应该仔细查看,因为我可以保证您的行为不会出现在其他硬件上 相同的rpm和XS7.2。 例如,我正在与其他硬件运行相同的配置而没有问题。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi cmarreel, Did you contact HP support? I still don't see how Nvidia could help here. If this would be a general issue with our vGPU manager I would agree to contact Nvidia but as this seems to be specific to your hardware, the OEM should have a closer look as I can guarantee that your behavior doesn't occur on other hardware with the same rpm and XS7.2. For example I'm running the same configuration with other hardware without issues. Regards Simon |
同样在这里
HP DL 380G9,Tesla M60 vGPU Manager(NVIDIA-vGPU-xenserver-7.2-384.99.x86_64)在重新启动后安装了100%FAN Speed。 卸载vGPU Manager然后正常FAN速度。 它是vGPU Manager中的一个Bug NVIDIA请帮忙! 以上来自于谷歌翻译 以下为原文 Same here HP DL 380G9, Tesla M60 vGPU Manager (NVIDIA-vGPU-xenserver-7.2-384.99.x86_64) installed then 100% FAN Speed after Reboot. Deinstall the vGPU Manager then normal FAN Speed. It is a Bug within the vGPU Manager NVIDIA pls help! |
为什么这是vGPU经理的错误?
这是HP特定的,所以请向HP提交一张票。 我们不以任何方式控制硬件风扇。 当然你也可以用ESP提交一张票,你认为这是与Nvidia相关的...... 以上来自于谷歌翻译 以下为原文 Why should this be a bug with vGPU manager? This is HP specific so please file a ticket with HP. We don't control the hardware fans in any way. For sure you can also file a ticket with ESP is you think this is Nvidia related... |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3818 浏览 4 评论
/9
GMT+8, 2025-12-1 11:13 , Processed in 0.992030 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3047
