电子发烧友论坛|
您好,我想使用一对E1437A ADC进行高达8 MHz的频谱分析,并可选择显示交叉频谱。
由于我有限的VEE经验,这看起来像是一项艰巨的任务,特别是因为我还不熟悉VXI乐器。 我可以从哪些程序模块开始? 即使是E1437A的波形采集也会非常有用。 谢谢,阿德里安 以上来自于谷歌翻译 以下为原文 Hello, i would like to use a pair of E1437A ADC's for spectrum analysis up to 8 MHz, with the option to display cross spectrum. Due to my limited VEE experience, that looks like a massive task, especially as I'm not yet familiar with VXI instruments. Are there any program modules available that I could start from? Even waveform acquisition for the E1437A would be very helpful. Thanks, Adrian |
3个回答
哦,这有点回头;-)这些VXI仪器真正推动了即插即用驱动程序的开发 - 不知何故甚至工程师也不热衷于在VXI地址空间中调用寄存器!
所以第一个问题是,你设法让驱动程序工作吗? 我的目标是开始一些简单的事情,例如在插入测量之前获取序列号等。 我没有在我的VEE安装中看到该单元的示例 - 您可能在该仪器附带的CD上有一个或搜索此论坛...或者此处的其他人可能有使用该设备的经验。 一旦你完成了这个,我认为这将是相当简单的:设置采集,开始采集,获取数据,然后使用VEE相当整洁的工具从时域到频域交换 - 我想你甚至可以把 一个波形(阵列映射到时间)直接进入幅度谱显示,它将为你做FFT。 让我们知道你在这方面取得了多大的成就,也许这里有人能够推动你迈向下一步。编辑:Mike于2015年3月18日上午3:41 以上来自于谷歌翻译 以下为原文 Ooh, that's going back a bit ;-) These VXI instruments were really what drove Plug-and-Play driver development - somehow even engineers weren't keen on poking registers in the VXI address space! So the first question is, have you managed to get the driver working? I'd aim for something simple to start with such as fetching the serial number or the like before plunging into a measurement. I don't see an example for that unit in my VEE installation - you might have one on a CD that came with the instrument or do a search of this forum... or maybe someone else here has experience with the device. Once you've done that though, I would imagine it would be fairly straightforward: set up the acquisition, start the acquisition, fetch the data and then use VEE's rather neat tools to swap from time to frequency domain - I think you can even put a waveform ( array mapped to time ) straight into a magnitude spectrum display and it'll do the FFT for you. Let us know how far you've made it towards doing that and maybe someone here willl be able to nudge you along to the next step. Edited by: Mike on Mar 18, 2015 3:41 AM |
bgvywerq 发表于 2018-10-1 19:40 迈克,非常感谢你回复我的帖子。 不幸的是,我没有带有软前面板程序,DSP函数库和示例程序的原始磁盘。 我刚买了一个VXIplug& play驱动程序,它应该支持VEE7并且仅在WIN95 / 98和NT上运行。 这可能解释了为什么我在发送的每个命令上都收到一条'未知警告代码'消息。 除此之外它似乎响应,但我必须确认每一个警告......当我尝试直接I / O时,我可以(至少)读取仪器ID。 但是,直接I / O会使事情变得更加困难,因为手册中只有一个命令列表。 没有示例如何使用E1437A,甚至没有概念。 此类或类似数字化仪卡(E1429,E1430,E1439,...)的任何示例程序都有助于入门。 阿德里安 以上来自于谷歌翻译 以下为原文 Mike, many thanks for getting back on my post. Unfortunately, I do not have the original disks with a soft front panel program, DSP function library and example programs. I just got a VXIplug&play driver that is supposed to be supported up to VEE7 and running on WIN95/98 and NT only. That might explain why I'm getting an 'unknown warning code d' message on every command I send. Beyond that it appears to respond, but I have to confirm every single warning... When I try direct I/O, I can (at least) read the instrument ID. However, direct I/O would make things a lot more difficult as there is only a command list in the manual. There are no examples how to work with the E1437A, not even a concept. Any example programs for this or a similar digitizer card (E1429, E1430, E1439, ...) would help getting started. Adrian |
HELLOKITTYNEW 发表于 2018-10-1 19:47 嗯,我很害怕,我无法深入挖掘。 在某个论坛帖子的某个地方有一个归档,但是它现在似乎处于离线状态。 不幸的是,VEE Pro并不是Keysight最喜欢的产品,因此很难获得制造商的支持(虽然它的用户很热情:-))我认为你的手册就是这个(另一个论坛成员友情指出):http: //www.google.com/url?q=http://application-notes.digchip.com/018/18-24834.pdf&sa=U&ei=HxUMVa-3E4rk8gW87YHwDw&ved=0CBQQFjAA&usg=AFQjCNGJZQsaY3ouYMOjAmVkKTa- TSjlOw我可能在上个世纪末参与某些数据acq示例(包括运行培训课程)。 如果我碰到任何我会告诉你,但我不愿意这样做。 我的建议是暂时停下来考虑你的选择。 例如,如果绝对需要使用该硬件,那么它可以完成,但是你知道现在将涉及比原先想象的更多的工作 - 例如你(或你为此目的参与的人)可以启动旧的 NT机器,使用P& P驱动程序执行所需操作,然后使用IO监视器对直接I / O“驱动程序”进行反向工程,或者只需花时间通过尝试直接I / O命令来了解它们。 鉴于这些信息,您可以通过明显更好的支持来平衡不同/更新近硬件的时间和精力。 我敢说,但你可能会找到更好的支持使用不同编程语言的旧乐器 - 但这也需要一些时间来适当调查。 HTH 以上来自于谷歌翻译 以下为原文 Hmm, I haven't been able to dig up very much I'm afraid. There is an archive somewhere of forum posts going _way_ back, but it seems to be offline at the moment. Unfortunately VEE Pro is not a favourite product of Keysight and so it struggles for support from the manufacturer ( although its users are enthusiastic :-) ) I presume the manual you have is this one ( kindly pointed out by another forum member ): http://www.google.com/url?q=http://application-notes.digchip.com/018/18-24834.pdf&sa=U&ei=HxUMVa-3E4rk8gW87YHwDw&ved=0CBQQFjAA&usg=AFQjCNGJZQsaY3ouYMOjAmVkKTa-TSjlOw I might have some data acq examples somewhere as I was involved at the end of the last century ( including running training courses ). If I come across any I'll let you know but I wouldn't bank on that. My advice would be to pause at this point and consider your options. For example, if there is an absolute requirement to use that hardware then it could be done but you know now there's going to be more work involved than originally thought - for example you ( or someone you engage for the purpose ) could fire up an old NT machine, do what you need with the P&P driver and then, using the IO Monitor, reverse engineer a direct I/O 'driver' or simply spend the time learning what the direct I/O commands are by trying them out. Given that information, you might balance that time and effort against different / more recent hardware with obviously better support. Dare I say it but you might find better support for older instruments with a different programming language - but that will also take some time to investigate properly. HTH |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 06:18 , Processed in 0.780094 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2887
