电子发烧友论坛|
嗨,大家好,我是PIC32新手。我习惯于PIC12PIC24。根据我对较小图片的设计,决定频率似乎很容易。但是现在使用和声配置器的PIC32 MZ1024EFG100,我不太确定。我使用一个12MHz的外部晶体(如果我需要以后的USB),但我的系统总线设置为约50MHz。没有特别的原因。我最终将使用/驱动一个TFT(16BPP)。我要和谐地测试PWM,所以我需要公式的外围频率。PWM是用于TFT背光和另一套为1kHz的可变占空比。外围频率设置为约25MHz。但我开始思考什么是更好的频率……嗯…我真的不知道。最初的输出频率被设置为200兆赫……似乎太过了…但这是因为我习惯了在PIC18S或PIC24S中的4MHZ-24MHz。BTW这不是电池操作的产品…最终。我想我应该看看FFRQ对我以后需要的PWMS和I2C会有什么更好的效果,但是我想知道人们的意见。谢谢。
以上来自于百度翻译 以下为原文 Hi all, I'm new to PIC32. I'm used to PIC12-PIC24. Deciding the frequency seemed easy based on my design for the smaller PICs. But now for a PIC32MZ1024EFG100 using the hARMony configurator, I'm not so sure. I'm using a 12MHz external crystal (in case I need USB later) but I have the system bus set to about 50MHz. No particular reason why. I'll be using/driving a TFT (16BPP) eventually. I was going to test the PWM in harmony so I need the peripheral frequency for the formula. PWM is for the TFT backlight and another set for 1KHz with variable duty cycle. The peripheral frequency is set for about 25MHz. But I starting to think about what would be a better frequency and ....well... I don't really know. Initially the output freq. was set to 200MHz....that seemed excessive ... but that's because I'm used to the 4MHz-24MHz in the PIC18s or PIC24s. BTW this will not be a battery operated product... eventually. I suppose I should see what freq. would work better for the PWMs and I2C that I'll need later but I want to know people's opinions. Thanks |
4个回答
嗨,在PIC32中,外部XTAL对FoC几乎没有影响,因为内部PLL可以实现与Fosc相同的任何XTAL FRQ。所以,本质上讲Fosc是更好的。我会说,如果你不关心功耗,你应该以高PB频率运行。如果你使用的是FoC= 200 MHz,那么你需要决定PB(外围总线)的划分因子。100MHz(1/2)通常是一个很好的选择,因为它提供了高分辨率,并且如果使用LCC库,则对于外部XTAL,CPU负载和高定时器解决方案的CPU负载最小,对于EMI BU来说越低越好。也许你也可以使用一个具体的音量,然后你可以利用它的价格。不要去高(16/24兆赫),以避免EMI问题。内部倍频产生较少的电磁干扰。
以上来自于百度翻译 以下为原文 Hi, In PIC32, the external XTAL has almost no influence on the Fosc because there are internal PLLs which can achieve the same Fosc whatever the XTAL freq. So essentially it is better to talk about Fosc. I would say that if you do not care about power consumption you should run at a high PB frequency. If you use Fosc = 200MHz, then you need to decide the division factor for PB (Peripheral Bus). 100MHz (1/2 ) is generally a good choice as it gives a high resolution and if you use LCC library you'll have the least CPU load and high timer resolution For external XTAL, the lower the better for EMI but maybe you also use a specific one in volume and then you can take advantage of its price. Don't go to high (16 / 24 MHz) to avoid EMI issues. Internal frequency multiplication generates less EMI. Regards |
R:水晶。一定要阅读勘误表。EF启动器套件使用一个外部振荡器的原因…我通常运行SysCLK在峰值处理要求所需的最小余量,然后将不同的其他时钟域划分为它们所需的最小值。我通常在1:1运行PBSCLK为SysClk & lt;100MHz,否则2: 1.No.12MHz振荡器不能获得“好”的SysClk值(只能使用PLLIDIV= {1,1,2})。如果你想要USB和“好”的SysCLK值,你必须使用一个24MHz的PLLIDEV=3。
以上来自于百度翻译 以下为原文 Re: crystal. Be sure to read the errata. The 'EF starter kit uses an external oscillator for a reason... I usually run sysclk at the minimum required for peak processing requirements with some headroom, then divide down the various other clock domains to the minimum they require. I usually run PBCLKs at 1:1 for sysclk<100MHz, otherwise 2:1. Note with a 12MHz oscillator you won't get 'nice' sysclk values (you can only use PLLIDIV={1,2}). If you want USB and 'nice' sysclk values you have to use a 24MHz with PLLIDIV=3. |
如果你将使用电池,现在就为它设计。即使不是,热量管理也是一个因素。唤醒外围时钟是最低的,将允许所有波特率或操作模式,你想要的。
以上来自于百度翻译 以下为原文 If you will be using battery, design for it now. Even if not, heat management is a factor. Wake the peripheral clocks be the lowest that will allow all baud rates or operating modes that you desire. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 06:49 , Processed in 0.788158 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
527
