电子发烧友论坛扫一扫,分享给好友
嗨,
我有一个109V2和10轴模块124V1。我想自定义FW以进行日志记录,但是在步骤4中存在问题: 1.使用Dfuse Demo下载DFU补丁和eMotion FW没有任何问题,一切都很好看,我可以使用Unico来查看/记录所有必要的数据。 DFU_Patcher_V1.0.2.dfu eMotionV2_REL_3_0.dfu 2.通过IAR for ARM 6.60编译eMotion源代码(eMotionV2_REL_3_0)(使用30天评估版本)。一切都还好。 文件eMotion.hex在文件夹EMOTION_FLASH中生成。 3.由DFU文件管理器V3.0.1将.hex文件转换为.dfu。没问题。 4.使用Dfuse Demo将.dfu文件下载到MIK109V2。该过程在最终状态下失败。错误消息是: ''目标00:验证成功,但数据不匹配......'' 你能建议如何解决这个问题吗? 谢谢, Taddy。 以上来自于谷歌翻译 以下为原文 Hi, I have a 109V2 and the 10-axis module 124V1. I want to customize the FW for logging, but there is a problem at the step 4: 1. Use Dfuse Demo to download the DFU patch and eMotion FW without any problems, all look good, I can use Unico to see/log all necessary data. DFU_Patcher_V1.0.2.dfu eMotionV2_REL_3_0.dfu 2. Compile the eMotion source code (eMotionV2_REL_3_0) by the IAR for ARM 6.60 (using the 30 days evaluation version). All are okay. The file eMotion.hex is generated inside the folder EMOTION_FLASH. 3. Convert the .hex file to .dfu by DFU file manager V3.0.1. No problem. 4. Use Dfuse Demo to download the .dfu file to the MIK109V2. The process is failed at the final state. The error message is: ''Target 00: Verify successful, but data not matching...'' Can you advise how to resolve this problem? Thanks, Taddy. |
1个回答
你好Taddy,
我相信你选择了错误的项目配置。实际上你确实选择了“EMOTION_FLASH”工作空间来生成DFU(这不起作用)而不是“EMOTION_DFU”。编译完工作区后,您将不得不使用目录“EWARM EMOTION_DFU Exe”中包含的hex文件。 如果这解决问题,请告诉我。 谢谢, 蒂亚戈 以上来自于谷歌翻译 以下为原文 Hello Taddy, I believe you are selecting the wrong project configuration. In fact you did choose “EMOTION_FLASHâ€� workspace to generate the DFU (this will not work) instead of “EMOTION_DFUâ€�. After compiling this workspace, then you will have to use the hex file contained in the directory “EWARMEMOTION_DFUExeâ€�. Let me know if this solve the issue. Thank you, Thiago |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 07:15 , Processed in 0.987123 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1222
