电子发烧友论坛|
刚刚给MtCube直接订购了ATBTLC1000 ZR XSTK XPLED启动套件。据我所知,这是基于Atmel(ARM)范围的。虽然我已经阅读了很多文档,但如果您需要额外的硬件来配置/编程这些设备,还不完全清楚。我知道一个程序员需要一个Atmel控制器,但初学者工具包有这个内置到主板,或什么是需要起床和运行?以前的蓝牙模块我使用的行为只是调制解调器,所以它是用AT命令设置并保存到NVM。如果有人能够确认是否需要“程序员”,我将不胜感激。谢谢你的任何帮助…T Yorky
以上来自于百度翻译 以下为原文 Just placed an order with Mchip direct for the atbtlc1000zr-xstk Xplained Starter Kit. As I understand it, this is based on the Atmel (ARM) range. Although I have read much of the documentation it is not exactly clear if you need additional hardware to configure/program these devices. I understand that a programmer is needed for an ATMEL controller but does the starter kit have this built into the main board, or what ever is needed to get up and running? Previous Blue tooth module I have used acts just as a modem so it is set up with AT commands and saved to NVM. I would appreciate it if somebody could confirm if any 'programmer' is needed? Thanks in advance for any assistance... T Yorky |
4个回答
嗨,BTLC1000就像BM70/BM71.它是一个简单的蓝牙模块,它需要一个外部主机MCU来控制它,它没有ASCII命令,但有下级命令。在Atmel Studio+ASF/Stand中,有很多使用外部的MCU的项目,如SAML21/L22/D20/D21……所以你需要使用。一个SAML21或其他XPLIN PRO启动工具包,您可以插入BTLC1000 XPLIF PROF,如果您想使用ASCII命令,那么您可以使用RN870/RN871+外部PIC微控制器。最综合的解决方案是SAMB11模块,它是一个包括用户MCU和BLE RF的SOC模块。模块。它有一个非常小的尺寸和一个专用的XPLAN板(ATSAMB11ZR XPRO)
以上来自于百度翻译 以下为原文 Hi, BTLC1000 is like BM70/BM71 it is a simple bluetooth module which needs an external Host MCU to control it. It does not have ASCII commands but lower level commands. There are lots of out of the box projects in ATMEL studio + ASF/START using external MCU like SAML21/L22/D20/D21... So you need to use a SAML21 or other XPLAINED PRO starter kit where you can plug the BTLC1000 xplained pro If you want to use ASCII commands then you can use RN4870 / RN4871 + external PIC microcontroller. The most integrated solution is the SAMB11 module which is a SoC which includes both the user MCU and the BLE RF module. It has a very small size and a dedicated XPLained board ( ATSAMB11ZR-XPRO ) Regards |
非常感谢快速回答RISC,我期待的套件是山姆L21 XPLAIN PRO和ATBTLC1000 ZR110 CA演示(模块加上几个传感器)的组合。山姆L21演示板有一个OnDeMeDemDeD调试器,我假定它与OnBabDATA SAML21J18B一起工作。但是从您所写的,不需要有什么程序来编程/调试ATBTLC1000ZR110 CA。这是由UART完成的,而不是AT命令,只是一个不同的协议。编辑哎哟。点击POST按钮!为什么它会有在实际的ZR1CA模块上提供的串行线调试(SWD)接口。此外,文档似乎写得好像它可以用作独立控制器,这是我的首选…我可能完全误解了这里的文档!Yorky!
以上来自于百度翻译 以下为原文 Thanks V much for the quick answer RISC, The kit I am expecting is a combination of the SAM L21 Xplained Pro and the atbtlc1000-zr110ca demo (module plus a few sensors). The SAM L21 demo board has an onboard Embedded Debugger which I presume works with the onboard ATSAML21J18B. But from what you have wrote, there is no need for something to program/debug the atbtlc1000-zr110ca. This being done by the UART, but not by AT commands, just a different protocol? Why would it have the Serial Wire Debug (SWD) interface provided on the actual zr110ca module. Also the documentation appears to be written as though it can be used as a stand alone controller, which is my preference... I may have totally misunderstood the documentation here though !! T Yorky. |
嗨,BTLC1000仅仅是BLE控制器,需要一个外部主机MCU(见模块数据表第18页第6段)。这就是为什么工具箱包含BTLC1000 BLE模块和外部SAM21处理器,BTLC1000内部处理器完全由蓝牙协议使用,不能由用户使用。SAMB11是一个单芯片(SoC),它包含用户的BLE和主机MCU,它有一个不同的初学者工具包:http://www. MICROCHEM.COM/…PATNONO=ATSAMB11ZR XPROSO,以明确:SAMB11模块= BTLC1000 +皮质M0+ MCU在BLE和用户应用之间共享。
以上来自于百度翻译 以下为原文 Hi, BTLC1000 is only BLE controller and need an external HOST MCU (see module datasheet page 18 paragraph 6). that is why the kit contains the BTLC1000 BLE module AND an external SAM21 processor The BTLC1000 internal processor is fully used by the bluetooth protocole and cannot be used by the user to put his application. The SAMB11 is a single chip (SoC) which contains the BLE and the Host MCU for the user. It has a different starter kit : http://www.microchip.com/...PartNO=ATSAMB11ZR-XPRO So, to make it clear : SAMB11 module = BTLC1000 + Cortex M0+ MCU shared between BLE and user application Regards |
谢谢你的澄清。我被ATBTLC1000数据表搞糊涂了。“Atmel®ATBTLC1000是一个集成了MCU、收发器、调制解调器、MAC、PA、TR交换机和电源管理单元(PMU)的超低功耗蓝牙®智能(BLE 4.1)系统。它可以作为一个蓝牙低能量链路控制器或数据泵与外部主机MCU或作为一个独立的应用程序处理器,具有嵌入式的LLE连接和外部存储器。“但是,ZZ模块不提供这个独立的选项。我已经订购了一个SAMB11套件,因为我正在寻找一个ST。单独安装。谢谢你的参考。我有其他的开发工具包。我第一次使用Atmel产品。Atmel Studio很好地集成到开发工具包中。对于使用1000兆ZR开发套件的任何人来说,没有一个SAML21/1000ZR组合的照片显示跳线位置。似乎100000 ZR的照片(在文本中显示)有错误的跳线位置。J101、J102、J103、J104应该是打开的。J105、J106、J107、J108应在UART位置(下侧丝网)。这些不是来自工厂的。“示例配置文件指南”描述了ZR模块符号所需的更改。我发现所有的例子都需要这样的改变来工作。
以上来自于百度翻译 以下为原文 Thanks for the clarification.. I have been confused by the ATBTLC1000 data sheet that says... "The Atmel® ATBTLC1000 is an ultra-low power Bluetooth® SMART (BLE 4.1) System on a Chip with Integrated MCU, Transceiver, Modem, MAC, PA, TR Switch, and Power Management Unit (PMU). It can be used as a Bluetooth Low Energy link controller or data pump with external host MCU or as a standalone applications processor with embedded BLE connectivity and external memory." But the _ZR module does not offer this standalone option. I have ordered up a SAMB11 kit as I am looking for a stand alone setup. Thanks for the reference. I had the other development kit delivered Thurs. First time I have used the Atmel products. Atmel studio very well integrated to the development kits. For anybody who is using the 1000_ZR development kit, there isn't a photo of the SAM L21/1000-ZR combination showing the jumper positions. It appears the photo (indicated in the text) of the 1000-ZR has the wrong jumper positions. J101, J102, J103, J104 should be open. J105, J106, J107, J108 should be in the UART position (underside silkscreen). And these are not as it came from the factory. The 'Example Profiles Guide' describes changes that are needed to the Symbols for the ZR module. I found that all the examples needed this change to work. Regards, T Yorky |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
454 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3529 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1094浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
457浏览 0评论
/9
GMT+8, 2025-12-1 15:50 , Processed in 0.606165 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2764
