你好。
我刚买了一台符合以下规格的Dell PowerEdge R720: 2个CPU E5-2650 v2 192 GB RAM,2个Perc RAID控制器(2个SATA) 1个NVidia Grid K1 vGPU卡 我按照这个程序: - 插入Dell Open Management光盘并使用Dell内置驱动程序执行Windows 2012 Datacenter R2 x64。 -Run Dell Bios Update for R720(v2.2.3)最新版本。 -run芯片组更新和support.dell.com推荐的驱动程序(根据我的服务标签) - 应用Windows更新并重新启动。 到目前为止系统还可以,但问题在下一步开始: - 重启后,安装NVidia Grid vGPU驱动程序332.83(http://www.nvidia.com/download/driverResults.aspx/74598/en-us) 安装此视频驱动程序后,我重新启动系统,当Windows徽标出现并等待点开始旋转时,屏幕变黑并持续几秒钟,然后我收到一个蓝屏: Page_Fault_In_NonPaged_Area(Nvlddmkm.sys) 然后系统收集一些数据并进入无限循环的重启。 如果我以安全模式启动服务器并删除驱动程序,一切正常。 我也尝试使用驱动程序333.11 for Grid K1并收到相同的错误。 有谁知道这是一个已知的问题,还是这张卡有更新或更稳定的驱动程序? 根据NVidia支持,Windows 2012 R2支持此卡。 我还尝试了TDR注册表项值来检测延迟但没有成功! (http://www.instructables.com/id/How-to-Fix-the-Nvlddmkm-Error/) 任何帮助将不胜感激! 提前致谢。 以上来自于谷歌翻译 以下为原文 Hello. I just bought a Dell PowerEdge R720 with the following specs: 2 x CPU E5-2650 v2 192 GB RAM, 2 Perc RAID controllers (2 SATA ) 1 NVidia Grid K1 vGPU Card I followed this procedure: -Insert Dell Open Management disc and perform Windows 2012 Datacenter R2 x64 with Dell built-in drivers. -Run Dell Bios Update for R720 (v2.2.3) latest version. -Run Chipset Update and recommended drivers from support.dell.com (according to my Service Tag) -Apply Windows Updates and reboot. The system is OK until now, but the problems begin in the next step: -after reboot, install NVidia Grid vGPU driver 332.83 (http://www.nvidia.com/download/driverResults.aspx/74598/en-us) after installing this video driver, I reboot the system and when Windows logo appears and waiting dots starts spinning the screen goes black for a couple of seconds and then I receive a blue screen: Page_Fault_In_NonPaged_Area (Nvlddmkm.sys) Then the system collects some data and enters an infinite loop of reboots. If I start the server in Safe Mode and remove the driver everything just works fine again. I also tried with driver 333.11 for Grid K1 and receive the same error. Does anyone know if this is a known issue or if there is any newer or stable driver for this card? According to NVidia support, this card is supported on Windows 2012 R2. I also tried the TDR registry key values for detection delay but no success! (http://www.instructables.com/id/How-to-Fix-the-Nvlddmkm-Error/) Any help will be appreciated! Thanks in advance. |
1个回答
您确定要将驱动程序安装在4 GB内存级别以下吗?
有一个关于戴尔和NVIDIA联合推出的戴尔R720中K1 / K2的具体安装过程的综合指南,虽然我现在似乎无法通过快速搜索找到它。 以上来自于谷歌翻译 以下为原文 Were you sure to install the driver below the 4 GB memory level? There is a comprehensive guide for the specific installation process for the K1/K2 in a Dell R720 that was jointly put out by Dell and NVIDIA some time ago, though I can't seem to find it with a quick search at the moment. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3125 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3531 浏览 4 评论
GMT+8, 2024-12-22 21:29 , Processed in 0.644936 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
