你好Nvidia,
我们是一家小型企业,最近为我们的办公室购买了电网K1和K2网格gpus,K2足以满足我们的需求。 我们非常担心发现nvidia不再发布网格驱动程序。 这是来自nvidia驱动程序站点的一行,“从版本375开始,NVIDIA驱动程序不再支持NVIDIA GRID K2,K1,K520和K340产品。” 如果nvidia停止发布网格GPU的驱动程序,他们应该至少提前24个月发出通知,这样人们就可以避免投资这些产品了。 做出决定并停止释放司机不应该是蓝色的。 我非常劝阻这种不良商业行为,并敦促Nvidia至少在未来24个月内释放司机。 谢谢 以上来自于谷歌翻译 以下为原文 Hello Nvidia, We are a small business recently bought grid K1 and K2 grid gpus for our office, K2 was more than sufficient for our need. We are very much worried to find nvidia is no longer releasing grid driver. Here is a line from nvidia driver site, "Beginning with Release 375, the NVIDIA drivers no longer support the NVIDIA GRID K2, K1, K520, and K340 products." If nvidia stops releasing driver for grid GPU, they should provide notice at least 24 months ahead, so people can avoid investing on these products. It shouldn't be out of blue to bring a decision and cease to release drivers. I highly discourage from such ill business practice and urge Nvidia to release drivers at least next 24 months. Thanks |
6个回答
NVidia应该回答并且应该设置GRID K *驱动程序的官方EOS日期(R367)。
我的观点:使用驱动程序分支R367作为GRID K *。 NVidia应该支持驱动程序分支R367直到2022年? https://gridforums.nvidia.com/default/topic/1094/nvidia-grid-vgpu/nvidia-grid-k2-with-hyper-v-2016/post/3980/#3980 以上来自于谷歌翻译 以下为原文 NVidia should answer and should set official EOS date for GRID K* drivers (R367). My opinion: Use driver branch R367 for GRID K*. NVidia should support driver branch R367 until 2022?. https://gridforums.nvidia.com/default/topic/1094/nvidia-grid-vgpu/nvidia-grid-k2-with-hyper-v-2016/post/3980/#3980 |
感谢MC的回复。
Nvidia已于2017年2月15日发布了Windows 10的新驱动程序,但对于GRID gpus来说并不新鲜。 以上来自于谷歌翻译 以下为原文 Thank you MC for your reply. Nvidia has released new driver for windows 10 in Feb 15 2017, but nothing newer for GRID gpus. |
是的,但是已经为R375和R378分支机构发布了驱动程序。
我测试了NVidia更改版本(5.2?)和VGX协议(guest-host vgpu协议)的内容,并且此驱动程序未附加到主机(VGX版本5.0 / 5.1)中的R367分支。 guest + Host的GRID 4.2驱动程序版本将于2017年3月底发布(可能更新分支R363和/或R367并发布新的R375(不支持GRID K *))(https://gridforums.nvidia.com/default/topic/ 1093 /职位/ 4031/4031#)。 我的观点:也许NVidia会向公众披露GRID路线图/支持信息(https://twitter.com/rhbBSE/status/829388848346124290)。 还有一个有趣的事情,Linux的R378驱动程序再次支持GRID K *(参见“支持的产品”http://www.nvidia.com/download/driverResults.aspx/115031/en-us)并且还有编译支持 用于KVM主机/管理程序。 以上来自于谷歌翻译 以下为原文 Yes, but drivers were released for branches R375 and R378. I tested that NVidia change version (5.2?) and content of VGX protocol (guest-host vgpu protocol) and this drivers does not attach to R367 branch in host (VGX version 5.0/5.1). GRID 4.2 driver release for guest+host is due end of March 2017 (probably update branch R363 and/or R367 and release new R375 (without GRID K* support)) (https://gridforums.nvidia.com/default/topic/1093/post/4031/#4031). My opinion: Maybe NVidia will disclosure GRID roadmap/support information to public (https://twitter.com/rhbBSE/status/829388848346124290). There is also one funny thing, R378 driver for linux supports GRID K* again (see "supported products" http://www.nvidia.com/download/driverResults.aspx/115031/en-us) and there is also compilation support for KVM host/hypervisor. |
嗨Syed,
首先,K1和K2卡是1年前EOL和GRID进入软件平台的。 使用新的驱动程序分支不支持K1 / K2是正确的,但这并不意味着这些卡不再有驱动程序。 R367分支将在未来几年得到支持(没有新功能,但错误修正)。 那么问题是什么? @mcerveny:我想这是最新Linux驱动程序的一个错误。 如果您查看自述文件,它会显示正确的信息: *剪断* 以下是统一驱动程序不再支持的旧GPU。 这些GPU将继续通过特殊的传统NVIDIA GPU驱动程序版本进行维护。 367.xx驱动程序支持以下一组GPU: NVIDIA GPU产品设备PCI ID * VDPAU功能 GRID K340 0FEF D. GRID K1 0FF2 D. GRID K520 118A D. GRID K2 11BF D. *剪断* 但是,多亏了这一点,以便我们可以纠正网站。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Syed, First of all K1 and K2 cards are EOL and GRID moved into a software platform 1,5 years ago. It is correct that there won't be support for K1/K2 with the new driver branches but it doesn't mean that there is no driver for these cards any more. The R367 branch will be supported for the next years (no new features but bugfixes). So what is the issue? @mcerveny: I guess this is just a mistake with the latest Linux driver. If you look at the readme it shows the correct information: *snip* Below are the legacy GPUs that are no longer supported in the unified driver. These GPUs will continue to be maintained through the special legacy NVIDIA GPU driver releases. The 367.xx driver supports the following set of GPUs: NVIDIA GPU productDevice PCI ID*VDPAU features GRID K3400FEFD GRID K10FF2D GRID K520118AD GRID K211BFD *snip* But thanks to bring this up so that we can correct the website. Regards Simon |
再次支持> 367.xx驱动程序版本(或NVidia再次出现)支持GRID K520。
NVIDIA-Linux的x86_64-384.111网/ README.txt文件 NVIDIA-Linux的x86_64-390.42网/ README.txt文件 NVIDIA-Linux的x86_64-390.48 // README.txt文件: *剪断* 附录A.支持的NVIDIA GPU产品 *剪断* A5。 NVIDIA GRID GPUS NVIDIA GPU产品设备PCI ID * VDPAU功能 ---------------------------------- --------------- - -------------- GRID K520 118A D. 以下是统一驱动程序不再支持的旧GPU。 这些GPU将继续通过特殊的传统NVIDIA进行维护 GPU驱动程序发布。 367.xx驱动程序支持以下一组GPU: NVIDIA GPU产品设备PCI ID * VDPAU功能 ---------------------------------- --------------- - -------------- GRID K340 0FEF D. GRID K1 0FF2 D. GRID K2 11BF D. *剪断* 以上来自于谷歌翻译 以下为原文 GRID K520 is supported in >367.xx drivers releases again (or NVidia lies again). NVIDIA-Linux-x86_64-384.111-grid/README.txt NVIDIA-Linux-x86_64-390.42-grid/README.txt NVIDIA-Linux-x86_64-390.48//README.txt: *snip* Appendix A. Supported NVIDIA GPU Products *snip* A5. NVIDIA GRID GPUS NVIDIA GPU product Device PCI ID* VDPAU features ---------------------------------- --------------- --------------- GRID K520 118A D Below are the legacy GPUs that are no longer supported in the unified driver. These GPUs will continue to be maintained through the special legacy NVIDIA GPU driver releases. The 367.xx driver supports the following set of GPUs: NVIDIA GPU product Device PCI ID* VDPAU features ---------------------------------- --------------- --------------- GRID K340 0FEF D GRID K1 0FF2 D GRID K2 11BF D *snip* |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2887 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3310 浏览 4 评论
GMT+8, 2024-6-26 19:33 , Processed in 0.572165 second(s), Total 54, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
