亲爱的各位,我使用的是以太网启动器KIT2和MPLAB和谐V2Y05Y01。我想从网页中控制LED。我运行的是PIC32的EthyWebSoServ.x程序,它在“WebSnEnthServ.NVMMMPFS”文件夹中运行。在编程之后,虽然我能够在“TCPIIPIOPENDER”中获取IP地址,但我无法打开网页。请指导我摆脱这个问题。谢谢。
以上来自于百度翻译 以下为原文 Dear all, I am using Ethernet starter kit2 and mplab hARMony V2_05_01. I want to control the LED's from web page. I am running 'pic32_eth_web_server.x' program, which in 'web_net_server_nvm_mpfs' folder. After programming,Though i am able to get the ip address in 'TCP_IP_DISCOVERER', i am not able to open the web page. Please guide me to get rid of this. Thank you. |
8个回答
嗨,我想我也有同样的问题!!!!请看这个讨论……http://www. McCys.com /论坛/ M1033.56.
以上来自于百度翻译 以下为原文 Hi, I think I had the same problem too!!!! Please see this discussion..... http://www.microchip.com/forums/m1032056.aspx#1032056 |
你好,萨沙,谢谢你的回复。我已经看过那个讨论了。你想让我把那个别针切掉22号看看
以上来自于百度翻译 以下为原文 Hi Sasa, Thank you for the reply. I have seen that discussion. You want me to cut that pin no 22 and see.? |
在Web浏览器中尝试使用“HTTPS”。例如:http://192.1681.23。
以上来自于百度翻译 以下为原文 In the web browser try using "https". For example: https://192.168.1.23 |
嗨,XorLor,谢谢你的回复。我尝试过“HTTPS”。但是它说“网站安全证书有问题”。我需要额外安装什么吗?
以上来自于百度翻译 以下为原文 hi XorLor, Thank you for the response. I have tried that 'https'. However it is saying 'There is a problem with this websites security certificate'. is anything extra i need to install? |
只需点击“继续这个网站”。演示Web页面应该加载。您也可以在WebSyVServ.NvMyMPFS文件夹中尝试该项目。它应该在没有HTTPS的情况下工作。
以上来自于百度翻译 以下为原文 Just click on "Continue to this Website". The demo web page should load. You can also try the project in the web_server_nvm_mpfs folder. It should work without https. |
大家好,我有个问题,EXK2上的U7真的是EEPROM吗?因为它是在这个组件上写的“5Le7088 3G”而不是“25LC256”和EEPROME Read OrthRead。
以上来自于百度翻译 以下为原文 Hello all, i've a question, U7 on ESK2 is really an EEPROM ? Because it's wrote on this component "5LEI70883G" and not "25LC256" and eeprom_read_write harmony's example isn't available for this board. Thanks in advance Regards |
只有小组成员才能发言,加入小组>>
5110 浏览 9 评论
1969 浏览 8 评论
1907 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3138 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2206 浏览 5 评论
679浏览 1评论
562浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
431浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
580浏览 0评论
477浏览 0评论
GMT+8, 2024-10-22 03:51 , Processed in 1.258451 second(s), Total 63, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
