电子发烧友论坛|
我使用PICtiT3编程PIC18F25K22。如果ID内存为空(0xFF一路),则启动一个序列来写入设备ID。每当我编程设备时,ID内存被擦除,即使保留ID内存复选框被检查。保持EEPROM工作,但保留ID内存DOE。我还没有尝试保存程序内存,并把ID地址地址范围放在那里,但是我认为保存ID内存选项应该这样做。拾取器3不能这样做吗?
以上来自于百度翻译 以下为原文 I am using PICKit3 to program a PIC18F25K22. If the ID memory is empty (0xFF all the way), a sequence is initiated to write the device ID. Every time i program the device, ID memory is erased, even though the Preserve ID Memory checkbox is checked. Preserving EEPROM works, but preserving ID memory does not work. I have yet to try Preserving Program Memory, and putting the ID Location address range in there, but I think that the Preserve ID Memory option should do this. Is the PICKit 3 incapable of doing this? |
1个回答
嗨,Suprastar,我们不能复制这个。我们编程55,AA,55,AA,55到用户ID区域。对设备进行编程。然后选择保存ID内存。编程11,11,11,11,11,但读回设备后,它读取55,AA序列。我们使用V4.15。这是你使用的版本吗?谢谢,霍华德
以上来自于百度翻译 以下为原文 Hi Suprastar, We were not able to duplicate this. We programmed 55,AA,55,AA,55 into the USER ID area. Programmed the device. Then selected to preserve ID memory. Programmed 11,11,11,11,11, but after reading back the device, it reads the 55,AA sequence. We used v4.15. Is that the version you used? Thanks, Howard |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
508 浏览 0 评论
5813 浏览 9 评论
2351 浏览 8 评论
2238 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3544 浏览 3 评论
1161浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1122浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
890浏览 1评论
508浏览 0评论
/9
GMT+8, 2025-12-14 15:56 , Processed in 0.463231 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2359
