电子发烧友论坛|
您好,我的8648D中的2 / 3A锂备用电池已经死了。
我没有一个方便,所以我连接了CR系列纽扣电池。 当我第一次恢复CAL数据时给单元上电,有时在上电时它会显示503消息,用于恢复衰减器校准数据(我假设是从EEPROM,它看起来像是cal,但消息很烦人。 我猜测我使用的电池可能没有足够的电压来保持内存备份,它只是根据需要恢复数据。我打算订购并安装正确的电池但我想知道为什么惠普不仅仅得到 来自EEPROM的校准数据。有没有人确切地知道这个电池实际备份了什么以及为什么该单元从SRAM中运行校准数据。这是因为速度吗?任何使用这些发电机的是德科技/惠普员工可以启发我 产品的设计/功能?任何CLIPS或详细的数据?由于这些已经失去支持多年,它们出现在剩余市场上,是业余无线电(火腿)工作台的精彩发电机。 如果是德科技会发布会很棒 8648系列的完整原理图和细节。 73. Sam W3OHM 以上来自于谷歌翻译 以下为原文 Hello, The 2/3A Lithium Back up battery in my 8648D is dead. I did not have one handy so I wired in a CR series coin cell. When I powered up the unit the first time it restored the CAL data, On occasion on power up it shows the 503 message for restoring the attenuator cal data (I am assuming from EEPROM, It appears to be in cal but the message is annoying. I am guessing that the battery I used may not be enough voltage to keep the memory backed up and it is just restoring the data as needed. I plan to order and install the correct one but I would like to know why HP did not just get the cal data from the EEPROM. Does anyone know exactly what this battery actually backs up and why the unit runs the cal data out of SRAM. Is it because of speed? Any Keysight/HP employees that worked on these generators that can enlighten me as to the design/function of the product? Any CLIPS or detailed data out there? Since these have been out of support for some years they are showing up on the surplus market and are wonderful generators for the amateur radio (ham) workbench. It would be wonderful if Keysight would release the full schematics and details of the 8648 series. 73. Sam W3OHM |
2个回答
锂电池用于备份SRAM中的工作校准数据以及用户设置。
当设备上电时,它会对工作校准文件与EEPROM文件进行校验和计数。 如果它匹配单元只是启动,如果没有,那么该单元将重新加载数据回到工作内存。 许多HP / Agilent产品都采用这种方式。 要正常工作的电池电量需要超过3.4伏才能在该型号中正常工作。 编辑:dhamilton于2016年2月3日下午4:31编辑:dhamilton于2016年2月3日下午4:34 以上来自于谷歌翻译 以下为原文 The lithium battery was to back up the working calibration data in the SRAM, as well as, user set ups. When the unit powers up, it does a checksum count of the working calibration file vs. the EEPROM file. If it matches the unit just powers up, if not then the unit will reload the data back into the working ram. Many HP/Agilent products worked that way. The battery level to work correctly needs to be over 3.4 volts to work correctly in that model. Edited by: dhamilton on Feb 3, 2016 4:31 PM Edited by: dhamilton on Feb 3, 2016 4:34 PM |
小佳99 发表于 2018-9-28 08:04 你好戴夫,根据数据表,BR-2 / 3A松下电池的标称电压为3V,那你的意思是2.4V吗? 如果我测量电池连接点与电池移除之间的电阻,我测得44K似乎很低。 我想知道在电池的某个地方是否有泄漏路径。 如果我连接电池,我测量电池的电压为2.8V,但是当设备通电时,它会抛出错误503步骤衰减器校准,每次设备通电时都会恢复。 如果我能找到主板的原理图,我相信我很容易找到问题所在。 即使是部分原理图也只包括电池备用电路会有所帮助。 山姆 以上来自于谷歌翻译 以下为原文 Hello Dave, The nominal voltage for the BR-2/3A Panasonic battery is 3V according to the data sheet so did you mean 2.4V? If I measure the resistance between the connection points of the battery with the battery removed I measure 44K which seems low. I am wondering if there is a leakage path somewhere past the battery. If I connect the battery I measure 2.8V across the battery but when the unit powers up it throws Error 503 Step Attenuator Cal Restored virtually every time the unit is powered up. If I could find a schematic for the motherboard I am sure that I could easily find the problem. Even a partial schematic the only includes the battery back up circuit would help. Sam |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1843浏览 0评论
415浏览 0评论
/9
GMT+8, 2025-12-1 16:39 , Processed in 0.929781 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
461
