大家好 - 可能是错误的地方,但我想我会提高它..
我试图通过以下设置验证H264客户端解码的使用: - 在ESXi 6.5上运行的Windows 10虚拟机。 VM具有使用P6-4Q配置文件分配的GRID P6 GPU - 瘦客户端是英特尔NUC的混合,但主要是奔腾(Gemini Lake)CPU(使用HD605 GPU)和带有集成HD620 GPU的i3 CPU(Kaby Lake) - NUC运行Ubuntu 18.04作为本地安装的操作系统(4.15.0-20-通用) - 安装的Horizon客户端是4.7.0 build 7395152 - Horizon Agent和Direct Connection插件的版本为7.4 我的目标是确认我的客户端是否正在将H264解码卸载到NUC GPU。 我的英特尔代表向我保证,上面提到的GPU能够实现此功能,但我看到Horizon客户端的信息告诉我这可能不会发生,如vmware-mksxxx.log文件中所示: - RemoteDisplay.allowClientH264 ='TRUE' 这是指Horizon Client GUI中H264解码的选项。 确认为在GUI中删除勾选时,该值变为'RemoteDisplay.allowClientH264 ='FALSE',没有进一步的H264 entriesRemoteDisplay.allowClientH264 ='FALSE - VNC客户端:H264硬件解码不可用 其他人在使用Horizon和GRID验证或验证硬件客户端解码时遇到问题? 谢谢 以上来自于谷歌翻译 以下为原文 Hi all - could be the wrong spot for this but thought i would raise it anyway.. I am trying to validate the use of H264 client decode with the following setup: - Windows 10 virtual machine running on ESXi 6.5. VM has a GRID P6 GPU assigned using a P6-4Q profile - Thin clients are a mix of Intel NUC but primarily Pentium (Gemini Lake) CPU (using HD605 GPU) and an i3 CPU (Kaby Lake) with an integrated HD620 GPU - NUCs run Ubuntu 18.04 as a locally installed OS (4.15.0-20-generic) - Horizon client installed is 4.7.0 build 7395152 - Horizon Agent and Direct Connection plug-in are at version 7.4 I am aiming to confirm whether my client is offloading H264 decode to the NUC GPU. I am assured by our Intel rep that the GPU mentioned above are capable of this function however i see information the Horizon client which tells me that this may not be happening, as per here in the vmware-mks-xxxx.log file: - RemoteDisplay.allowClientH264 = ‘TRUE’ This refers to the option for H264 decode in the Horizon Client GUI. Confirmed as when removing the tick in the GUI, the value becomes ‘RemoteDisplay.allowClientH264 = ‘FALSE’ with no further H264 entriesRemoteDisplay.allowClientH264 = ‘FALSE - VNC Client: H264 hardware decoding unavailable Anyone else have trouble validating or verifying hardware client decode using Horizon and GRID? Thanks |
6个回答
托比亚斯,
谢谢你的回复 - 我之前没有使用过这个工具。 我会调查。 尼尔 以上来自于谷歌翻译 以下为原文 Tobias, Thank you for your reply - i have not used this tool before. I shall investigate. Neal |
只是想报告这个非常有用的工具 - 它可以在没有订阅/捐赠的情况下使用,但如果您付费则可以提供改进的比较功能和信息。
它允许我验证在虚拟机上进行的编码虽然基本上不是端点的验证,所以基本上我的vGPU编码是工具确认的H264 NVENC,但是确认我的端点使用板载GPU进行解码需要一些东西 其他。 再次感谢Tobias 以上来自于谷歌翻译 以下为原文 Just wanted to report back on this very useful tool - it can be used without subscription/donation but offers improved comparison features and information if you do pay. It allowed me to verify the encoding being done on the virtual machine although not essentially the validation of the endpoint, so basically my vGPU encode is H264 NVENC as confirmed by the tool, but confirming my endpoint is decoding using onboard GPU is going to require something else. Thank you again Tobias |
我很高兴,@瑙鲁!
我们发现RDAnalyzer非常适用于各种用途。 我还强烈推荐GPUprofiler:https://github.com/JeremyMain/GPUProfiler/releases 以上来自于谷歌翻译 以下为原文 My pleasure, @Nealus! We have found RDAnalyzer extremely useful for all sorts of purposes. I can also highly recommend GPUprofiler: https://github.com/JeremyMain/GPUProfiler/releases |
该线程是关于端点解码的。
Windows上只有DXVA检查程序,您可以在使用Citrix Receiver时检查硬件解码是否在注册表中正常工作。 我不知道有一个工具可以为Linux Receiver做同样的事情。 不确定Horizon是否有相同的可能性来检查硬件解码是否正常工作。 通常,您可以检查Receiver / Agent中的端点进程,因为您应该看到CPU负载较高或较低... 问候 西蒙 以上来自于谷歌翻译 以下为原文 This thread is about endpoint decoding. There is only DXVA checker on Windows and you can for example check if the hardware decoding is working in the registry when using Citrix Receiver. I'm not aware of a tool that does the same for Linux Receiver. Not sure if there is the same possibility with Horizon to check if HW decoding is working. In general you can check the endpoint processes from the Receiver/Agent as you should see high or low CPU load... Regards Simon |
None
以上来自于谷歌翻译 以下为原文 Simon, Horizon has some verbose log entries i can search but I was seeking something definitive, like the registry entries for Citrix. The closest I have got is via the H264 check box in the Horizon client. Turn it on, the thin client CPU usage for the vmware-remotemk process drops by approx 50%. Pretty impressive especially when running dual 4K panels and full screen video :-) |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3124 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3531 浏览 4 评论
GMT+8, 2024-12-22 13:42 , Processed in 0.829299 second(s), Total 108, Slave 90 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
