电子发烧友论坛|
我在Replorer 8开发板中使用RS232协议,但仍然没有得到结果。起初,我认为MCP2221是UART协议的驱动程序,现在我发现它只是一个转换器,它能够将USB转换成UART/I2C,在这点上我是正确的吗?接下来,我需要一些跳线引脚的澄清。正如在用户指南中提到的,我在J53-J55和J54-J56之间连接了跳线。我看到USB 2用于这个实验,所以使用9V适配器并在J2中连接BRD 5V之间的跳线。这是正确的方法吗?然后我交叉连接了DX9连接器和PIC16F1719集成电路的TX-RX引脚,但是在超级终端中仍然得到一些垃圾值,并且我检查了我的程序和终端的波特率。下面附上代码,请参阅
以上来自于百度翻译 以下为原文 I'm working RS232 protocol in explorer 8 development board, but still i haven't get a result. Initially I thought that MCP2221 is a driver for UART protocol, now i found that it's just a convertor which is capable of converting USB to UART/I2C, Am i correct in this point? Next I need some clarifications in jumper pins. As mentioned in user guide i've connected the jumpers between J53-J55 and J54-J56. I seen that USB 2.0 is used for this experiment, so used 9V adapter and connected the jumper between BRD-5V in J2. Is this a correct way? Then i cross connected the TX-RX pins of DB9 connector and PIC16F1719 IC, but still i get some garbage value in hyperterminal and also i've checked the baudrate for my program and terminal. The code is attached below, please refer that Attachment(s) uart877A.txt (3.22 KB) - downloaded 37 times |
3个回答
因为这是你给出的关于你得到的结果的唯一细节,我猜波特率是不一样的,一个或者两个都太远了。
以上来自于百度翻译 以下为原文 As this is the only detail you give about what results you are getting I would guess the baud rates are NOT the same, one or both are too far out of tolerance. |
“现在我发现它只是一个转换器,它能把USB转换成UART/I2C,我在这一点上是正确的吗?”是的
以上来自于百度翻译 以下为原文 "now i found that it's just a convertor which is capable of converting USB to UART/I2C, Am i correct in this point?" Yes |
“UART协议”是什么意思?这不是一个标准术语。
以上来自于百度翻译 以下为原文 What exactly do you mean by "UART protocol" ? That is NOT a standard term. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 02:09 , Processed in 2.471291 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4046
