你好,
有人可以清楚需要安装什么版本的驱动程序? 在nvidia企业门户网站中我只看到一个4.6网格驱动程序(370.21),但我确实看到应该有更新的版本! (至少在vgpu驱动程序部分下,文件名是相同的:370.21_grid_win10_server2016_64bit_international.exe vs 391.58_grid_win10_server2016_64bit_international) hyperV主机本身是否需要任何驱动程序? 因为禁用和卸载主机中的GPU会使驱动程序无用我猜... 只有Guest VM中的驱动程序很重要? 以及如何许可? hyperV VM控制台默认在“增强会话”(RDP)中打开,但可以切换到“基本会话”,但屏幕只是保持黑色...... 在RDP会话中我无法打开nvidia控制面板...我在论坛中读到这应该在未来的版本中修复,这篇文章是在2017年的某些时候发布的... 我确实运行了几个测试,并使用gpuprofiler监视gpu利用率,看起来即使没有安装任何许可证也使用了gpu ... 谢谢 史蒂夫 以上来自于谷歌翻译 以下为原文 Hello, can someone clearify what version of what drivers needs to be installed? in nvidia enterprise portal i only see a 4.6 grid driver (370.21) but i do see that there should be newer versions too! (at least under the vgpu driver sections, file name is the same: 370.21_grid_win10_server2016_64bit_international.exe vs 391.58_grid_win10_server2016_64bit_international) are there any drivers needed on the hyperV Host itself? because disabling and dismounting the GPUs in Host makes the driver useless i guess... only the driver in the Guest VM matters?? and how to license? hyperV VM console does open in "enchanced session" (RDP) per default but can be switched to "basic session" but there the screen just stays black... and in RDP Session i can't open the nvidia control panel... i read in the forums here that this should be fixed in a future version, the post was from back in 2017 somewhat.. i did ran a a couple of tests and also monitored gpu utilization with gpuprofiler and it looks like the gpu is used even without any license installed... thx Steve |
6个回答
特斯拉M10 ......
基本上版本问题已经全部回答了...我确实只看到了旧软件,因为我的帐户中有一个旧的试用许可证..有了新的许可证,新版本也出现了! 以上来自于谷歌翻译 以下为原文 Tesla M10... basically the version question is answered allready... i did saw only old software because of an old trial license i had in my account.. with a new license, new versions appeared too! |
如何许可?
这取决于你想要达到的目标。 对于RDSH,您需要vApp CCU许可证,对于VDI,您需要vPC或QvDWS许可证。 问候 西蒙 以上来自于谷歌翻译 以下为原文 How to license? It depends what you want to achieve. For RDSH you would need vApps CCU licenses and for VDI you would need vPC or QvDWS licenses. Regards Simon |
是的,使用DDA(或视频卡passthrough的其他名称)。
您可以使用标准设备管理器通过标准RDP检查已安装的驱动程序 (如果没有附加或错误尝试重新安装RDP)。 网格4. [3-6]驱动程序370.xx for M10与WinServer 2016 1607 + 1709(请参阅https://docs.nvidia.com/grid/4.6/product-support-matrix/index.html)可以部署 许可证无知。 您可以忽略“许可证弹出”或停止许可证请求(删除“CurrentControlSet”中的regkey“GridLicensedFeatures”)。 但要注意Grid4.x驱动程序是故意留下的(搜索此论坛)。 Grid 5.x / 6.x驱动程序38x.x / 39x.x(也是WinServer 2016 1607 + 1709)(参见https://docs.nvidia.com/grid/6.0/product-support-matrix/index.html) 需要用于DDA的Quadro vDWS许可证(请参阅https://images.nvidia.com/content/grid/pdf/161207-GRID-Packaging-and-Licensing-Guide.pdf)。 以上来自于谷歌翻译 以下为原文 Yes, with DDA (or other name for video card passthrough). You can check installed driver over standard RDP with standard device manager. (If not attached or in error try to reinstall over RDP).
mcerveny,
您是否知道在许可之前是否存在演示期或测试硬件传递的方法? 我不想把钱花在对我们不起作用的事情上。 谢谢... 以上来自于谷歌翻译 以下为原文 mcerveny, Do you know if there is a demo period or a way to test the hardware pass through prior to licensing? I don't want to spend the money on something that will not work for us. Thanks... |
嵌入式演示期不存在。
但是有可能注册评估许可证(90天)和访问带有软件版本的企业门户 - http://www.nvidia.com/object/vgpu-evaluation.html并继续“软件下载”...... 以上来自于谷歌翻译 以下为原文 Embedded demo period does not exist. But there are possibility to register for evaluation licenses (90 days) and access to enterprise portal with software releases - http://www.nvidia.com/object/vgpu-evaluation.html and continue with "software download"... |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3082 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3498 浏览 4 评论
GMT+8, 2024-11-28 01:06 , Processed in 0.700506 second(s), Total 87, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
