我需要一些帮助计算在C8051上使用ADC测量的电压。我知道的REF电压是2.4V,它使用12位的步骤(从我的理解中得到4096,根据编程的最后一个人的笔记)。在我的读数中,我得到了8A ONADC0H和0D在ADC0L上。有了这些信息,有可能得到实际的电池电压被读取吗?
以上来自于百度翻译 以下为原文 I am in need of some help calculating the voltage measured using the ADC on a c8051. The ref voltage I know is 2.4volts and it is using a 12bit step (4096 from my understanding and according to the notes of the last guy who programmed this thing). It seems to have ADLJST set to right justify. In my readings I am getting 8A on ADC0H, and 0D on ADC0L. With that information, is it possible to get the actual battery voltage being read? |
3个回答
这是一个微芯片PIC论坛。Microchip不做一个“C8051”,ADC值应该是(Vin/2.4)* 2 ^ 12。很容易重新排列这个公式来计算Vin从ADC CONTUNNO的想法,这些寄存器,因为这不是PIC芯片。
以上来自于百度翻译 以下为原文 This is a Microchip PIC forum. Microchip do not make a "c8051" The ADC value should then be (Vin / 2.4) * 2^12 It's easy to rearrange that formula to calculate Vin from the ADC count No idea about those registers as this is not a PIC chip. |
事实上,他们现在是这样的。ATMEL AT89C51是8051个兼容设备。
以上来自于百度翻译 以下为原文 Well, actually, they sort of so now. The Atmel AT89C51 are 8051 compatible devices. http://ww1.microchip.com/downloads/en/devicedoc/doc4180.pdf |
很好的尝试,但该芯片不包含任何ADC外围设备。我假设OP是指硅实验室C8051 HTTPS://E.WiKiTo.Org/WiKi/C8051,它有很多种,有许多不同的ADC外围设备。它们有一个支持论坛AthTPS://www. SilabsCim/社区。
以上来自于百度翻译 以下为原文 Nice try, but that chip doesn't contain any ADC peripheral. I'm assuming the OP is referring to the Silicon Laboratories C8051 https://en.wikipedia.org/wiki/C8051 That comes in many varieties, with many different ADC peripherals available. They have a support forum at https://www.silabs.com/community |
只有小组成员才能发言,加入小组>>
4919 浏览 9 评论
1870 浏览 8 评论
1813 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3012 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2099 浏览 5 评论
514浏览 1评论
369浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
423浏览 0评论
311浏览 0评论
IPECMD命令烧录AVR128DA48芯片,报找不到芯片错误
794浏览 0评论
GMT+8, 2024-7-11 01:50 , Processed in 0.884775 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
