大家好。我试着对我的1个项目进行一个名称更改。这个旧名称的项目被编译并运行没有问题。1。在项目窗口中,单击项目的根目录右按钮。2。转到重命名并点击它。3。窗口以“项目名称”字段打开,并且“也重命名项目文件夹”单选按钮。4。当只更改“项目名称”时,我可以编译和运行,但名称本身在项目窗口中没有改变,这不是我的目标。5。因此,我标记“重命名项目文件夹”单选按钮,项目的名称在项目窗口中确实发生了变化,但是我不能用大量错误信息(见附件)6来编译它。我试图用XML来手动更改名称,但没有帮助。我错过了什么?酒吧。
以上来自于百度翻译 以下为原文 Hello all. I try to make a name change to 1 of my projects. The project on its old name was compile and run no problem. 1. I click right button on the root name of the project in the project window. 2. Go to Rename and click it. 3. the window open with "Project name" field, and "Also Rename Project Folder" radio button. 4. When changing only the "Project name" I could compile and run but the name itself didn't change in the project window and this is not my goal. 5. So I mark the "Also Rename Project Folder" radio button, and the name of the project really change in the project window but then I couldn't compile it with the lot of error messages (see attach) 6. I try to look in the xml to change manually the name but didn't help. What do I miss? Bar. Attachment(s) error renamemicrochip MPLAB X 4.15.txt (26.02 KB) - downloaded 4 times |
2个回答
一般工作中的重命名函数。但是如果您只重命名项目名称,那么MpLabX将不反映这一点,直到您关闭并重新打开项目。你仍然能看到旧的名字。如果你改变了项目名称和项目文件夹,那么MpLabX似乎隐式地做了这件事,一切都还好。但是如果你按顺序做这两件事(就像你做的那样),很难说你现在的状态是什么。除了你之外,没有人知道新的名字和新的名字。您似乎喜欢描述性和长名称,也可能会有一些副作用。C:/Microchip 0/0501/App/Word2ByTestBurthSePiSp100100Usand Officel100100518CalbyDalk01yTest/固件/Word2ByTestBrothStEnSePiSpLSi和AuthOfficel130518.XI建议返回您以前的版本。打开/备份并重新命名。
以上来自于百度翻译 以下为原文 The rename function in general works. But if you only rename the project name, then MpLabX will not reflect this, until you close and reopen the project. I.e you still see the old name. If you change both project name and project folder then MpLabX seems to do this implicitly, and everything is ok. But if you then do both in sequence (like you did) it's hard to tell what your current status is. Also nobody but you knows old and new names. You seem to like descriptive and long names, that also could have some side effect. C:/microchip/harmony/v2_05_01/apps/WEAR2B_testground_sine_steps_100us_and_officel_100518_calib_Dark01_test/firmware/WEAR2B_testground_sine_steps_and_officel_130518.X I would recommend to go back to your previous version / backup and do the rename again. |
当我玩弄其他一些我错误使用的项目时,我发现它是如何完成的(但不是逻辑上应该是这样)。1。在项目的下拉列表中更改项目的名称,如前所述,步骤1-4。2。不要标记“重命名项目文件夹”单选按钮。3。在文件管理器中将包含此项目的文件夹的名称更改为某个名称。然后,在MPLAB X中编译标题项目名称将更改为新的一个,并且它将被编译。我不知道后面的逻辑是什么,以及为什么“重命名项目文件夹”单选按钮也不会。做一些工作。
以上来自于百度翻译 以下为原文 When I play around with some other project I use by mistake I found how it can be done (but not logically as it should be). 1. Change the name of the project in the drop down list of the project DO step 1-4 as I describe before . 2. don't mark "Also Rename Project Folder" radio button. 3. Change the name of the folder contain this project in the file manager, to the some name. After that and compile the header project name in MPLAB X will be change to the new one and it will compile. I don't know what the logical behind it, and why the "Also Rename Project Folder" radio button doesn't make the some work. |
只有小组成员才能发言,加入小组>>
5088 浏览 9 评论
1958 浏览 8 评论
1893 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3123 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2192 浏览 5 评论
641浏览 1评论
525浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
384浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
548浏览 0评论
451浏览 0评论
GMT+8, 2024-10-6 14:55 , Processed in 3.491759 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
