电子发烧友论坛|
我正在使用labview来控制S系列示波器。
我想让示波器记录许多不同的测量值,以便我可以将它们卸载到电子表格中。 我遇到的测量是模拟通道1上升时模拟通道2上的电压测量。 我是否因为查看测量选项而遗漏了某些内容,或者我是否只能使用光标进行测量? 以上来自于谷歌翻译 以下为原文 I'm using Labview to control an S-Series scope. I want to have the scope record a number of different measurements so I can offload them to a spreadsheet. The measurement I'm having trouble with is a voltage measurement on analog channel 2 when analog channel 1 rises. Am I missing something from looking at the measurement options or can I only get this measurement by using the cursors? |
3个回答
我不确定你到底想要什么。
在捕获中,通道1“仅上升”一次吗? 您是否在通道1超过某个阈值的确切时刻寻找通道2上单个捕获点的电压值? 这需要一点思考和编程。 由于上升时间是有限的,非零,也许你正在寻找通道2在通道1上升的某个短时间内的平均电压? 如果通道1在捕获期间仅上升一次,则相对容易...在通道1上触发,在通道2上设置“水平门”,然后在门功能的输出上进行电压测量。 免责声明:为了获得更可靠的响应时间,您应该考虑致电当地的Keysight技术呼叫中心。 Keysight论坛在“可用”的基础上进行监控,并不一定是解决技术问题的最快方式。 以上来自于谷歌翻译 以下为原文 I'm not sure exactly what you want here. Does Channel 1 "rise" only once in a capture? Are you looking for the voltage value of single captured point on Channel 2 at the exact instant that Channel 1 crosses some threshold value? This requires a little thought and programming. Since the rise time is finite, and non-zero, maybe you're looking for the average voltage on Channel 2 during some short time period during which Channel 1 is rising? If Channel 1 only rises once during a capture this is relatively easy... Trigger on Channel 1, set up a 'Horizontal Gate' on Channel 2, then put a voltage measurement on the output of the gate function. Al Disclaimer: For more reliable response times, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
通道1在捕获中仅上升一次。
理想情况下,是的,当通道1超过阈值时,我正在寻找通道2上的单个电压值。 现在考虑到这可能很困难,我认为如果窗口相对较小,我可以使用通道2的平均值。 我将尝试使用水平门,看看这是否足以满足我的目的。 谢谢你的回复。 以上来自于谷歌翻译 以下为原文 Channel 1 will rise only once in a capture. Ideally, yes, I am looking for the single voltage value on channel 2 when channel 1 passes a threshold. Now given this may be difficult, I think I could live with an average value of channel 2 if the window is relatively small. I will experiment with the Horizontal Gate to see if this will be accurate enough for my purposes. Thanks for the response. |
毛新宇的儿子王大锤 发表于 2018-9-24 09:21 门窗可以任意小。 您应该记住存在一些示波器噪声,并且您可能希望限制测量的BW,因此10到20个样本宽的门可能是正确的。 人 以上来自于谷歌翻译 以下为原文 The gate window can be arbitrarily small. You should remember that there is some scope noise, and that you probably want to limit the BW of your measurement, so a gate that's 10 to 20 samples wide is probably about right. Al |
只有小组成员才能发言,加入小组>>
250 浏览 0 评论
1863 浏览 0 评论
2753 浏览 1 评论
2656 浏览 1 评论
2477 浏览 5 评论
1863浏览 0评论
431浏览 0评论
253浏览 0评论
/9
GMT+8, 2025-12-11 23:44 , Processed in 0.545496 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
942
