我想知道是否可以看到每个VM的vGPU利用率。
不在操作系统内,而是来自Grid K1卡。 例如,如果GPU 0为80%,那么如果我知道45%的数字来自特定的VM,那就太棒了。 我查看了论坛,但没有找到任何具体的帖子。 我尝试使用nvidia-smi CLI命令。 例如:'nvidia-smi -q',但它显示了每个物理GPU的详细信息,包括利用率。 每个虚拟机利用率都没有。 谢谢,我感谢您对此请求的任何帮助。 以上来自于谷歌翻译 以下为原文 I want to know if it is possible to see the vGPU utilization per VM. Not within the OS but from the Grid K1 card. For instance, if GPU 0 is at 80%, it would be great if I knew 45% of that number is coming from a specific VM. I looked through the forums but didn't find any specific posts on this. I tried using nvidia-smi CLI command. For instance: 'nvidia-smi -q' but while it showed detailed info on each physical GPU, including utilization. There was no per VM utilization. Thanks and I appreciate any help on this request. |
24个回答
嗨雷切尔,
实际上,7.0.1更新没有解决PCoIP会话。 更令人困惑的是,当我用VMWare提出一张票时,他们的记录中甚至没有触及这个主题的内容。 他们希望与NVIDIA的联系人联系,告诉他们有关问题的更多信息,以便他们能够将问题正确地发送给他们的工程部门。 我发现他们的回答非常奇怪,当你将KB 1735009传给他们时,你会非常友善地告诉我你在VMWare与谁联系过吗? 有人必须知道这个问题,因为他们修复了BLAST协议...... 谢谢雷切尔, 帕斯卡尔 以上来自于谷歌翻译 以下为原文 Hi Rachel, indeed the 7.0.1 update did not resolve PCoIP sessions. What is even more confusing is that when I raised a ticket with VMWare, they dont even have anything in their records that touches this subject. They would like to get a contact person at NVIDIA to tell them more about the problem so that they can properly send the issue to their engineering department. I find that their answer is very strange, would you be so kind and tell me who you are in contact with at VMWare when you passed along the KB 1735009 to them? Somebody must know about this problem since they fixed it for the BLAST protocol... Thanks Rachel, Pascal |
我通过私信给你发了个联系方式。
多么奇怪... 雷切尔 以上来自于谷歌翻译 以下为原文 I have sent you a contact via private message. How strange... Rachel |
“我想知道是否有可能看到每个VM的vGPU利用率。”
你问,所以我们现在添加了:-D https://blogs.nvidia.com/blog/2016/08/24/nvidia-grid-monitoring/ 英国下午4点/太平洋夏令时间上午8点举行网络研讨会,您可以提出问题 http://info.nvidianews.com/aug24_webinar.html 以上来自于谷歌翻译 以下为原文 "I want to know if it is possible to see the vGPU utilization per VM." You asked, so we have now added :-D https://blogs.nvidia.com/blog/2016/08/24/nvidia-grid-monitoring/ There's a webinar at 4pm UK/8am PDT today where you can ask questions http://info.nvidianews.com/aug24_webinar.html |
好消息!
遗憾的是,这些更改未针对支持K2板的GRID版本实施。 也许下次还是这个消息建议我用GRID 2.0跳上特斯拉M60? :-) 以上来自于谷歌翻译 以下为原文 Great News! Unfortunate that these changes were not implemented for the GRID version that supports K2 boards. Maybe next time or is this a message advising me to jump on the Tesla M60 with GRID 2.0 ? :-) |
从历史上看,大多数GPU供应商已经将GPU作为纯硬件销售,虽然这意味着没有持续的软件许可,但它是一种不支持软件的模型,其中卡的功能是通过购买的物理硬件规范来修复的。
开普勒K1 / K2卡在这种型号下销售。 认识到这种模式不符合客户对24/7支持的期望,并且软件的增强功能使用软件组件开发和销售较新的卡,该软件组件使客户能够在其现有硬件上开发新的软件功能。 因此,仅针对在诸如M10 / M6 / M60的软件模型下开发的新产品开发了新的监控功能。 NVIDIA继续提供您购买卡时可用的功能。 NVIDIA _is_致力于长期可用性和持续回归测试。 开普勒GRID卡即将推出。 NVIDIA完全致力于支持和维护客户购买Kepler时可用的功能。 GRID软件平台允许用户管理具有Kepler卡的主机以及具有Maxwell代卡的主机的环境。 允许用户扩展以在新一代中使用新功能。 在虚拟化VDI环境中,服务器和管理程序认证由管理程序供应商和服务器OEM驱动。 服务器OEM更喜欢支持有限的组合以确保完整的测试覆盖率,因此很少为较旧的服务器添加对较新GPU的支持。 同样,虚拟机管理程序供应商很少向较旧的稳定和经过测试的平台添加新功能,选择将测试重点放在新版本上以确保质 对于具有如此多技术交互的每个变体,组织必须平衡添加和测试新体系结构和功能的需求,并通过在新技术而不是旧版本上扩展测试矩阵来完全测试它们。 GRID 2.0及以上产品的软件许可投资于开发支持和测试的软件功能,例如新的监控功能 类似的更新功能,如支持和开发VMware BLAST Extreme和Linux VDA支持,一直专注于软件支持的卡M60 / M10 / M6。 以上来自于谷歌翻译 以下为原文 Historically most GPU vendors have sold GPUs as pure hardware and whilst this meant no ongoing software licensing it is a model without support for the software where the functionality of the card is fixed with the physical hardware specification purchased. The Kepler K1/K2 cards were sold under such a model. Recognizing this model does not fit with customer expectations for 24/7 support and enhancements to the software newer cards are developed and sold with a software component that enables and entitles the customer to the development of new software features on their existing hardware. As such the new monitoring functionality has only been developed for newer products developed under a software model such as the M10/M6/M60. NVIDIA continues to provide the features and functionality that were available when you bought your cards. NVIDIA _is_ committed to long term availability and continual regression testing. The Kepler GRID cards are coming towards their end of availability. NVIDIA is fully committed to supporting and maintaining the functionality that was available on the Kepler generation when customers bought them. The GRID software platform allows users to manage environments with hosts that have Kepler cards alongside hosts with Maxwell generation cards. Allowing users to expand to use new features on newer generations. In a virtualized VDI environment the server and hypervisor certification is driven by the hypervisor vendors and server OEMs. Server OEMs prefer to support limited combinations to ensure full test coverage and as such rarely add support for newer GPUs to older servers. Likewise hypervisor vendors rarely add new features to older stable and tested platforms choosing to focus the testing on new releases to ensure quality. For every variation with so many technologies interacting at some point organisations have to balance the need to add and test new architectures and features and test them fully by expanding the test matrix on newer technologies rather than older versions. The software licensing of GRID 2.0 and up products is invested in the development of supported and tested software features such as the new monitoring functionality Similarly newer features like support and development for VMware BLAST Extreme and Linux VDA support have been focused on the software supported cards M60/M10/M6. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3069 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3485 浏览 4 评论
GMT+8, 2024-11-22 08:40 , Processed in 0.958461 second(s), Total 53, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
