电子发烧友论坛|
当我拉出一张牌时会发生什么...并且让我们说总共3张牌只剩下2张。
有没有办法告诉用户附加什么特定的卡?...假设所有卡都在相同的esxi主机? 所以我在一台主机上有3张卡。 一旦卡坏了......我在服务器上取下死卡。 只剩2个。 现在是什么?死卡上的用户有vGPU驱动程序,但没有K2卡?..从我所看到的这是允许工作..他们只是没有获得实体卡的好处.. vGPU驱动程序 如果没有卡,似乎仍然让用户进入。 抱歉可能回答我自己的问题 - 可能拉死卡..在esxi主机上转到CLI ..使用nvidia-smi查看谁还在上? 这可能是最好的方式吗? vcenter会以某种方式告诉我谁是一张卡片上的卡片吗?..通过内存使用来分类VDI可能吗?..看看谁保留了它? 非常感谢 以上来自于谷歌翻译 以下为原文 what happens when i pull one card out.. and lets say there are only 2 left from a total of 3. Is there any way to tell what users are attached to what specific card ?.. assuming all cards are in the Same esxi host ? So i have 3 cards in one host. Once card goes bad... I down the server take the dead card out. Only 2 left. now what ?.. users on the dead card have the vGPU driver but no K2 card ?.. from what i have seen this is allowed to work.. they just don't gain the benefit of the physical card.. the vGPU drivers appears to still let the user in if there is no card. sorry probably answering my own question - probably pull the dead card.. goto CLI on the esxi host.. use the nvidia-smi to see who actually is still on ? that the best way probably ? will vcenter show me somehow who is attached to a card or not ?.. sort VDI's by memory use maybe ?..see who has it all reserved ? thanks much |
1个回答
vCenter / Horizon Manager不会向您提供此信息
你可以通过Nvidia-smi获得它 XenServer将为您提供可视化表示哪些VM连接到哪个GPU。 以上来自于谷歌翻译 以下为原文 vCenter / Horizon Manager does not give you this information You can obtain it via Nvidia-smi XenServer will give you a visual representation of which VM's are attached to which GPU. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3818 浏览 4 评论
/9
GMT+8, 2025-12-2 01:45 , Processed in 1.622392 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2260
