您好,我正在使用2端口E8362C,运行固件版本,A.09.42.22。
使用DCOM。 至少对我来说,我发现了一个真正的问题。 我正在测试放大器,还有一个信号增强放大器来增强驱动信号。 当固件运行时,我有一个“安全”的用户预设设置,这样如果在增压放大器打开时按下预设按钮,则什么都不会爆炸。 但是,我今晚发现,如果我关闭固件并点击预设按钮,那么所有的赌注都会关闭。 PNA固件像平常一样启动,并且应用了工厂预设,在整个过程中接通电源,并且我在参考接收器上的电量比我想象的要多。 幸运的是,我在R1前面有20 dB的衰减器。 无论如何,我认为如果先前为PNA定义并设置了用户预设文件,那么无论固件是否打开,当我点击预设按钮时,我应该获得用户预设,而不是工厂预设。 我想这可以做到。 可以吗? 这对我来说似乎很关键。 最好的问候,安迪 以上来自于谷歌翻译 以下为原文 Hello, I am working with an 2-port E8362C, running firmware version, A.09.42.22. Using DCOM. I have discovered a real problem, for me at least. I am testing amplifiers and also have a signal booster amplifier to boost the drive signal. When the firmware is running, I have a "safe" user preset setup so that if the preset button is pressed while the booster amp is on, nothing blows up. However, I found tonight that, if I close the firmware and hit the preset button, then all bets are off. The PNA firmware is started like normal and the factory preset is applied, power is turned on throughout this process, and I put way more power on my reference receiver than I ever wanted to. Fortunately I had 20 dB attenuator in front of R1. Regardless, I think that if a user preset file was previously defined and set properly for the PNA, then whether the firmware is open or not, when I hit the preset button, I should get the user preset, never the factory preset. I would imagine this could be done. Can it be done? It seems critical to me. Best regards, Andy |
1个回答
这似乎可以被认为是一个错误。
但是之前没有人抱怨过。 不过,它应该是固定的。 以上来自于谷歌翻译 以下为原文 This does seem like it could be considered a bug. But no one has ever complained before. Still, it should be fixed. |
只有小组成员才能发言,加入小组>>
1070 浏览 0 评论
2306 浏览 1 评论
2093 浏览 1 评论
1967 浏览 5 评论
2838 浏览 3 评论
837浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
616浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
713浏览 0评论
1397浏览 0评论
1071浏览 0评论
GMT+8, 2024-9-29 20:14 , Processed in 1.216357 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
