你好,
我们正在尝试在我们的Microsoft hyper-v服务器上部署nVidia Tesla m60作为DDA,并在hyper-v主机上安装驱动程序时遇到问题。 现在两张卡在设备管理上都带有感叹号。 当我转到属性时,我看到错误: Windows已停止此设备,因为它已报告问题。 (代码43) 在事件查看器中我看到了: 驱动程序管理结束了为设备实例ID PCI VEN_10DE& DEV_13F2& SUBSYS_113A10DE& REV_A1 6& 17F903& 0& 00400010安装驱动程序nvgridsw.inf_amd64_571ee27dd7a55054 nvgridsw.inf的过程,其状态如下:0x0。 驱动程序管理已经结束了为设备实例ID PCI VEN_10DE& DEV_13F2& SUBSYS_113A10DE& REV_A1 6& 17F903& 0& 00400010添加服务nvlddmkm的过程,具有以下状态:0。 设备PCI VEN_10DE& DEV_13F2& SUBSYS_113A10DE& REV_A1 6& 17f903& 0& 00400010需要进一步安装。 删除了设备PCI VEN_10DE& DEV_13F2& SUBSYS_113A10DE& REV_A1 6& 17F903& 0& 00400010。 类Guid:{00000000-0000-0000-0000-000000000000} 服务器是戴尔R730 还有一件事,当我们为这个nVidia M60安装驱动程序时,服务器似乎重启了两次,它似乎试图安装驱动程序,然后失败然后重新启动以删除驱动器或smth。 也许有人之前遇到过这种问题? 提前致谢。 以上来自于谷歌翻译 以下为原文 Hello, we are trying to deploy nVidia Tesla m60 as DDA on a our Microsoft hyper-v server and getting issues with installing driver on hyper-v host. Now both cards appear with exclamation point on device management. When i goto properties i see error: Windows has stopped this device because it has reported problems. (Code 43) in Event Viewer i see those: Driver Management concluded the process to install driver nvgridsw.inf_amd64_571ee27dd7a55054nvgridsw.inf for Device Instance ID PCIVEN_10DE&DEV_13F2&SUBSYS_113A10DE&REV_A16&17F903&0&00400010 with the following status: 0x0. Driver Management has concluded the process to add Service nvlddmkm for Device Instance ID PCIVEN_10DE&DEV_13F2&SUBSYS_113A10DE&REV_A16&17F903&0&00400010 with the following status: 0. Device PCIVEN_10DE&DEV_13F2&SUBSYS_113A10DE&REV_A16&17f903&0&00400010 requires further installation. Device PCIVEN_10DE&DEV_13F2&SUBSYS_113A10DE&REV_A16&17F903&0&00400010 was deleted. Class Guid: {00000000-0000-0000-0000-000000000000} Server is Dell R730 and one more thing, when we installing driver for this nVidia M60, server it seems restart two times,it seems trying to install driver, then fails and then restart again to remove drive or smth. Maybe someone met this kind of issue before? Thanks in advance. |
2个回答
嗨,
您尝试安装哪个驱动程序版本? 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi, which driver version did you try to install? Regards Simon |
西蒙你好,
我尝试过那些: NVIDIA-GRID-Windows的390.75-391.81 NVIDIA-GRID-Windows的384.155-386.57 NVIDIA-GRID-Windows的367.128-370.28 我正在从每个包中安装grid_win10_server2016_64bit_international驱动程序。 我错了吗? 在所有尝试问题是相同的。 谢谢。 以上来自于谷歌翻译 以下为原文 Hello Simon, I have tried those: NVIDIA-GRID-Windows-390.75-391.81 NVIDIA-GRID-Windows-384.155-386.57 NVIDIA-GRID-Windows-367.128-370.28 I am installing grid_win10_server2016_64bit_international driver from each package. May i wrong? On all tries issue is the same. Thanks. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3004 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3420 浏览 4 评论
GMT+8, 2024-10-6 06:37 , Processed in 0.598173 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
