电子发烧友论坛|
W3631A和W3636A(非堆叠)DDR3 x16命令和数据探针有什么区别?
什么意思,非堆叠? 我的DUT运行的是单片MT41J128M16(16 Meg x 16 x 8 Bank),DDR3-1600。 以上哪一个是正确的订购? 以上来自于谷歌翻译 以下为原文 what is the difference between W3631A and W3636A (non-stacked) DDR3 x16 command and data probes ? what does it mean, non-stacked ? My DUT is running with a single chip of MT41J128M16 (16 Meg x 16 x 8 Banks), DDR3-1600. which one of mentioned above is correct to order ? |
3个回答
Alx,如论坛的各个地方所述,它们用于点对点互动,它们不能替代直接联系Keysight的技术呼叫中心。 任何是德科技人员都不会定期监控它们。 如果您希望将来有关产品相关问题的快速,可靠的答案,请与技术呼叫中心联系。 人 以上来自于谷歌翻译 以下为原文 Alx, As stated in various places throughout the forums, they are intended for peer-to-peer interaction, and they are not a replacement for contacting the Technical Call Center at Keysight directly. They are not monitored on a regular basis by any Keysight personnel. If you want a quick, reliable answer about product-related issues in the future, please get in touch with the Technical Call Center. Al |
非堆叠意味着单个芯片,堆叠意味着双芯片。
一些供应商将单个芯片封装称为SDP,将双芯片封装称为DDP,将四芯片封装称为QDP。 如果芯片具有多个芯片选择,则将其堆叠。 在查看MT41J128M16的Micron数据手册(第17页引脚分布图像)时,芯片似乎没有多个芯片选择,但是当您在使用的部件上搜索信息时,有多个部件以此编号开头也是 有一个后缀(-xxx)。 请检查您的确切信息。 W3630A系列数据手册还列出了给定BGA内插器不可用的信号(参见以下第7页:http://literature.cdn.keysight.com/litweb/pdf/5990-3179EN.pdf?id = 1648244 )。 如果您不需要访问A15或BA2,则可以使用W3631A。 以上来自于谷歌翻译 以下为原文 Non-stacked means single die, stacked means dual die. Some vendors refer to a single die package as SDP, dual die package as DDP, and quad die package as QDP. If a chip has more than one chip select, it is stacked. When looking at the Micron data sheet for the MT41J128M16 (page 17 pinout image) the chip doesn't appear to have multiple chip selects however when searching for information on the part you're using there are multiple parts that begin with this number that also have a suffix (-xxx). Please check for the exact information on your part. The W3630A series data sheet also lists what signals are NOT available for a given BGA interposer (see page 7 of the following: http://literature.cdn.keysight.com/litweb/pdf/5990-3179EN.pdf?id=1648244). You would use the W3631A if you don't need access to A15 or BA2. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 03:53 , Processed in 0.809382 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5307
