电子发烧友论坛|
亲爱的,我试着实现一个简单的程序来学习如何使用DMA功能。我计划把数据发送到DMA,我希望DMA会自动发送数据到SPI缓冲器。首先,我检查了SPI功能。它正按照我的需要将数据发送到传感器。之后,我尝试添加一个DMA功能。不幸的是,我失败了,我没有发送任何数据。我正在使用一个DSPIC33 EP128EP204处理器。配置是用MCC帮助生成的。请找到我的代码(附件中的完整代码):int main(空隙){StaseRealAlgLimeIZE();//启用全局中断StuttTyGloAlnEnable();DMAYPurrulalAddiSrsSSET(0,and;SPI1BUF);DMAYPurralIrqNoMultBuSET(0,10);DMAYRealToCurtTeSET(0,1);DMA-ChhannNel启用(0);/*DMA0ReqBist.For=1;QBITS.FULL=1);IEC0BITS.SPI1IE=1;*/DMAIOffice ToRelGelEngult(0);DMAIL旗舰中断清除(0);而(1){//SPI1Exchange 16位(0xAAAA);/ /添加您的应用程序代码}返回0;}我将非常感谢任何帮助。
C(2.14 KB)-下载42次MCC.C(7.79 KB)-下载43次SPI1.C(7.16 KB)-下载49次Mealth.C(0.62 KB)-下载46次 以上来自于百度翻译 以下为原文 Dear All, I tried to implement a simple program to learn how to use a DMA feature. I planned to send data to DMA, and I hoped that DMA will automatically send data to the SPI buffer. Firstly, I have checked an SPI functionality. It was sending data to the sensor as I wanted. After that, I tried to add a DMA functionality. Unfortunately, I failed and I didn't manage to send any data. I am working a dsPIC33EP128EP204 processor. Configuration was generated with MCC help. Please find my code (full code in attachments) : int main(void) { SYSTEM_Initialize(); // Enable the Global Interrupts INTERRUPT_GlobalEnable(); DMA_PeripheralAddressSet(0,&SPI1BUF); DMA_PeripheralIrqNumberSet(0,10); DMA_TransferCountSet(0,1); DMA_ChannelEnable(0); /* DMA0REQbits.FORCE=1; while (DMA0REQbits.FORCE == 1); IEC0bits.SPI1IE = 1; */ DMA_SoftwareTriggerEnable(0); DMA_FlagInterruptClear(0); while (1) { //SPI1_Exchange16bit(0xAAaa); // Add your application code } return 0; } I will be grateful for any help. Sincerely xyz Attachment(s) dma.c (4.56 KB) - downloaded 42 times interrupt_manager.c (2.14 KB) - downloaded 42 times mcc.c (7.79 KB) - downloaded 43 times spi1.c (7.16 KB) - downloaded 49 times main.c (0.62 KB) - downloaded 46 times |
2个回答
你好,请在这里找到带有DSPIC33的DMA的SPI代码示例CE416。
以上来自于百度翻译 以下为原文 Hi, Please find herewith the code example CE416 for SPI with DMA on dsPIC33EP Regards Attachment(s) CE416_SPI_loopback_DMA_corrected.zip (129.83 KB) - downloaded 33 times |
MCC中的HiSPI仅支持增强的操作模式。在DMA功能的情况下,SPI仅在标准模式下。(参考FRM获取更多信息)ThanksMCC Team。
以上来自于百度翻译 以下为原文 Hi SPI in MCC is supported for Enhanced mode of Operation only. In case of DMA functionality, SPI should be in standard mode only.(Refer FRM for more information). Thanks MCC Team |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
473浏览 0评论
/9
GMT+8, 2025-12-1 20:17 , Processed in 0.623949 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2939
