电子发烧友论坛|
就像在主题中一样,我想尝试在EMPro中模拟近场模拟。
我是研究生,我只是这个应用程序的初学者。 在我的项目中,我真的需要使用近场模拟。 在教程视频中,它只有远场FTDT。 如果有人知道如何在近场模拟或有一些材料这样做,请告诉我。 谢谢 编辑:2016年1月26日下午5:37成为RF工程师 以上来自于谷歌翻译 以下为原文 Like in the topic, I want to try to simulate near-field simulation in EMPro. I'm a graduate student and I'm just a beginner to this application. In my project, I really need to use near-field simulation. In the tutorial videos, it only has FTDT for far-field. If someone know how to simulate in near-field or have some material to do so, please let me know. Thank you Edited by: To be RF engineer on Jan 26, 2016 5:37 PM |
2个回答
你想用什么引擎?
如果您使用FDTD,请设置传感器(例如平面传感器)以收集近场数据。 如果使用FEM,则存储将存储三维字段的字段数据,该字段也是字段数据附近。 以上来自于谷歌翻译 以下为原文 What engine do you want to use? If you use FDTD, please set up a sensor (say, planar sensor) to collect the near field data. If you use FEM, then store the field data which will store the 3-dimensional field, which is also near field data. |
iwqudwnd 发表于 2018-9-17 17:04 我有疑问 如果有可能从近场模拟获得辐射模式(如在远场模拟中)(我试图模拟这么多次并且在模拟完成之前花了很长时间)并且我不确定我是否能够获得 数据形式的数据,例如辐射强度在特定区域(例如距离天线3毫米)的数量,而不是3D形式。 另外,如果我必须使用其他传感器(在FEM中),我应该使用哪一个? 还有一个问题,我如何从模拟中导出结果。 谢谢。编辑:2016年2月16日下午7:41成为RF工程师 以上来自于谷歌翻译 以下为原文 I have questions. If it possible to get the radiation pattern (like in the far field simulation) from near-field simulation (I tried to simulate so many times and it took so long before the simulation is done) and I'm not sure if I can get the data such as how much the radiation intensity is in the specific area (like 3 millimeters from antenna) in the numerical form, not in the 3D form. In addition, if I have to use others sensors (in FEM), which one I should use? One more question, how can I export the result from simulation. Thank you. Edited by: To be RF engineer on Feb 16, 2016 7:41 PM |
只有小组成员才能发言,加入小组>>
237 浏览 0 评论
1859 浏览 0 评论
2752 浏览 1 评论
2655 浏览 1 评论
2477 浏览 5 评论
1859浏览 0评论
431浏览 0评论
245浏览 0评论
/9
GMT+8, 2025-12-11 05:11 , Processed in 3.890659 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1260
