电子发烧友论坛|
背景:MPLAB X IDE 4.15,XC32 V2.05,和声V2.05,PIC32 MZ2048 EFH100I有一段时间试图让模拟器在这种情况下工作。我确实意识到,它可能无法正常工作,因为支持是在测试与编译器和处理器的模拟器。不过,我已经尝试了一个PIC32 MX处理器选择也没有用。我也把优化级别改为零,没有用;编译器抱怨这里的和谐库是建立在至少优化级别1上的。我只是想用一个DMA通道在一个丢弃的测试程序中运行CRC引擎。我用我的实际项目成功地完成了这项工作,所以我知道代码是可以的。我尝试测试CRC-ccITT(XMODEM),如果我在安装过程中出错,不必连续编程。
以上来自于百度翻译 以下为原文 Background: MPLAB X IDE 4.15, XC32 v2.05, HARMony v2.05, PIC32MZ2048EFH100 I'm having a devil of a time trying to get the simulator working in this situation. I do realize that it may not work properly as the support is at Beta for the Simulator with this compiler and processor. Still, I've tried this with a PIC32MX processor selected to no avail either. I've also changed the optimization level to zero to no avail; the compiler complains here that Harmony's libraries were built to work with at least optimization level 1. I'm simply trying to run the CRC engine with a DMA channel in a throw-away, test program. I do this successfully with my actual project, so I know that the code is ok. I'm trying to test out CRC-CCITT (XMODEM) without having to continually program the device if I've made mistakes in the setup. |
3个回答
模拟器不支持所有外围设备。如果你去仪表板,点击“点击这里为模拟外围设备”按钮,你会得到一个实际实现的外围设备列表。我认为DMA是,但不认为CRC是。
以上来自于百度翻译 以下为原文 The simulator doesn't support all peripherals. If you go to the Dashboard and click on the "Click Here for Simulated Peripherals" button you'll get a list of peripherals that are actually implemented. I think DMA is, but don't think CRC is. |
抱歉迟到的家伙,但我有困难访问论坛。我最终创建了一个一次性项目来测试它。CCITT相当直截了当。
以上来自于百度翻译 以下为原文 Sorry for the late replay guys, but I was having trouble accessing the forums. I ultimately just created a throwaway project to test it. CCITT was pretty straightforward. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1122浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 00:31 , Processed in 0.808901 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2151
