我试图在paralell(从2台计算机上运行)中运行2个不同的测试,其中一个34980,发送SCPI命令。
为了防止在访问仪器的同时我一直在玩签证锁定/解锁功能。 这个想法是每个测试在执行步骤之前检查“锁定”标志是否清楚,否则它会等待一段时间并再次检查。 问题在于,由于每个测试都与不同的签证对象相关联(即使它是相同的仪器),因此有2个不同的标志,每个标志只能从自己的电脑上访问。 有人建议如何使这项工作? 谢谢 以上来自于谷歌翻译 以下为原文 I've trying to run 2 different tests in paralell (run from 2 computers) with one 34980, sending SCPI commands. In order to prevent access to the instrument at the same time I've been playing with the visa lock / unlock functions. The idea is that each test checks for the "locked" flag to be clear before performing a step, else it waits a while and checks again. The problem is that since each test is linked to a different visa object (even if it's the same instrument) then there are 2 different flags, each one only accesible from its own pc. Anybody have some suggestions on how to make this work? Thanks |
1个回答
您需要使用VXI-11 LAN连接(TCP IP :: IP ADDRESS :: inst0 :: INSTR),并且您需要使用Exclusive Locks。
以上来自于谷歌翻译 以下为原文 You need to use a VXI-11 LAN connection (TCPIP::IP ADRESS::inst0::INSTR), and you need to use Exclusive Locks. |
只有小组成员才能发言,加入小组>>
1226 浏览 0 评论
2348 浏览 1 评论
2159 浏览 1 评论
2024 浏览 5 评论
2905 浏览 3 评论
970浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
703浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
803浏览 0评论
1226浏览 0评论
GMT+8, 2024-11-24 08:01 , Processed in 1.035246 second(s), Total 49, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
