电子发烧友论坛|
我们将Agilent 34980与34921A模块一起用于我们的一些数据收集。
校准大型机和模块的最佳方法是什么? 它们应该一起校准还是可以单独校准? 这些项目是否应该由安捷伦重新校准,或者其他“校准室”可以处理这样的任务吗? 提前谢谢,丹 以上来自于谷歌翻译 以下为原文 We use Agilent 34980's with 34921A Modules for some of our data collection. What is the best approach for calibration of both the mainframe and the modules? Should they be calibrated together or can they be calibrated seperately? Are these items something that should be re-calibrated by Agilent or can other "calibration houses" handle such a task? Thanks in advance, Dan |
1个回答
34980A DMM校准通过左侧小盖板后面的背板Dsub连接器完成,如手册中所示。
任何有设备的校准室都可以进行校准。 在34921A中无需校准,但如果您正在进行任何两线电阻测量,那么检查通道电阻是个好主意。 Y1131A测试和验证软件(免费下载)和Y1131A-001测试夹具是测试通道电阻的推荐方法。 “服务指南”中有一个可选的热电偶参考温度传感器验证程序。 以上来自于谷歌翻译 以下为原文 The 34980A DMM calibration is done through the backplane Dsub connector behind the little cover on the left side as shown in the manual. Any calibration house that has the equipment can do the cal. There's nothing to calibrate in the 34921A although it's a good idea to check the channel resistance if you are doing any two wire resistance measurements. The Y1131A Test and Verification software (free download) and the Y1131A-001 test fixture are the recommended way to test channel resistance. There is an optional thermocouple reference temperature sensor verification procedure in the Service Guide. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 13:49 , Processed in 0.546994 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1350
