电子发烧友论坛|
您好,我刚刚被介绍到该设备,我想知道它是否可以帮助我做一些我正在计划的实验。
实验的基线是在环境中发送一些无线信号并在发射器处测量反射波,然后对接收到的信号进行一些处理以提取有关环境的一些信息。 我可以离线进行处理,所以我只是坚持进行测量。 我想扫描1到2 GHz的频率,能够测量接收信号的幅度和相位。 我可以使用FieldFox RF矢量网络分析仪N9923A吗? 如果是这样,你能提供一些指导材料吗? 谢谢。 以上来自于谷歌翻译 以下为原文 Hello, I have just been introduced to the device and I was wondering if it could help me do some experiment I am planning. The baseline of the experiment is to send some wireless signal in the environment and measure the reflected wave back at the transmitter, then do some processing on the received signal to extract some information about the environment. I can do the processing offline so I am just stuck with getting the measurements. I want to sweep frequencies from 1 to 2 GHz with the ability to measure the magnitude and phase of the received signal. Can I do this using FieldFox RF Vector Network Analyzer N9923A? If so, can you please provide some guiding material? Thanks. |
1个回答
你能更清楚地说明测量吗?
这是一个无线测量,你将有一个天线连接到FieldFox的源端口(1),另一个天线连接到FieldFox的接收器端口2? 你会测量S21,看看幅度和相位吗? 某些类型的校准可能是必要的。 以上来自于谷歌翻译 以下为原文 Can you clarify the measurement more? Is this an over the air measurement, where you will have an antenna connected to FieldFox's source port (1) and another antenna connected to FieldFox's receiver port 2? Would you be measuring S21, and looking at both magnitude and phase? A calibration of some type maybe necessary. |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 05:35 , Processed in 1.055248 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1308
