HW:PIC32 MZ2064 DAB28 8启动套件安装在MEB II评估板上。框架:协调2.05i尝试管理连接在J7连接器上的USB桥接器(USB类型A型连接器用于PIC32 USB主机应用)。N通过MHC:USB堆栈中断模式UbSySpultHyth-MSD主机客户端驱动程序。文件系统Service AutoNoutt特性FAT文件系统SysffsMyAyAype类型MSD文件系统类型FATOTO应用层I在SDCARDMSDFATYFAX多DISK上进行ISRIPION。ER与咏叹调列表小部件(文件名和图标)。发生的是,有时它工作,有时不。这意味着有时我可以检测到连接并读取根目录的文件数据,有时我无法检测到连接状态。我所看到的最后一件事是,我对UsHSSL Geuntin VBueSerr有很多调用到ErdRvuSubsHsHoothTasksIsR(文件DrvuSubHsHuth.c)。错误在哪里?我需要在启动工具包/EVE板上设置一些设置吗?我可以在SW中检查什么?
以上来自于百度翻译 以下为原文 HW: PIC32MZ2064DAB288 starter kit mounted on MEB II evaluation board. FRAMEWORK: HARMont 2.05 I'm trying to manage a USB pendrive connected on J7 connector (USB Type-A connector for PIC32 USB host based applications). I started from aria_coffee_maker example and added USB feature by setting application via MHC: USB Stack interrupt mode USB_SPEED_HIGH MSD Host Client Driver. File System Service Automount feature FAT File System SYS_FS_MEDIA_TYPE_MSD with file system type FAT For application layer I took ispiration on sdcard_msd_fat_multi_disk. What I'm planning to build is (for the moment) a file browser with aria list widget (file names and icons). What's happening is that sometimes it works and sometimes not. It means that sometimes I can detect the connection and read root directory's file data, sometimes i can't detect the attach status. The last thing I've seen is that I have a lot of call to _DRV_USBHS_HOST_Tasks_ISR (file drv_u***hs_host.c) with USBHS_GENINT_VBUSERR. Where's the mistake? Do I need to make some setting on starter kit / eval board? What can I check in sw? |
2个回答
你能得到USB主机MSD基本演示在板上工作吗?
以上来自于百度翻译 以下为原文 Have you been able to get the USB host MSD basic demo to work on the board? |
请稍后回答。问题是板上的电源。如果我用PC供电的程序运行,微控制器重置在无用的电源上。如果我在墙上安装的电源设备上运行板,它就会运行。我现在的问题是:我能调试(PC上的USB J16)PIC32 MZDA启动器套件和MEBII,而它的电源与墙壁安装电源?7000 05311A数据表谈到了JP1跳线,但我找不到它在我的板上。
以上来自于百度翻译 以下为原文 Excuse me for the late on answer. The problem is on board power. If I run the program with boards powered by PC the microcontroller reset on insufficent power. If I run powering the boards from wall mounted power supllier, it run! My question, now, is: Can i debug (PC on USB J16) PIC32MZDA Starter Kit and MEBII while it's powered with wall mounted power supplier? The 70005311A datasheet spoke about a JP1 jumper, but i cannot find it on my boards. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 03:28 , Processed in 0.746834 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1477
