我使用的是JLINKV8,某宝上的买的。这个JLINK的1脚和2脚是相连的。和一般的有点不一样。
我用它在下载程序的时候出现了这个问题。很奇怪。请大婶帮我看看 SEGGER J-Link GDB Server V4.92 Command Line Version JLinkARM.dll V4.92 (DLL compiled Sep 30 2014 09:33:42) -----GDB Server start settings----- GDBInit file: none GDB Server Listening port: 2331 SWO raw output listening port: 2332 Terminal I/O port: 2333 Accept remote connection: localhost only Generate logfile: off Verify download: on Init regs on start: on Silent mode: off Single run mode: on Target connection timeout: 5 sec. ------J-Link related settings------ J-Link Host interface: USB J-Link script: none J-Link settings file: none ------Target related settings------ Target device: MKL16Z256xxx4 Target interface: SWD Target interface speed: 2000kHz Target endian: little Connecting to J-Link... J-Link is connected. Firmware: J-Link ARM V8 compiled Dec 1 2009 11:42:48 Hardware: V8.00 S/N: 304230680 Feature(s): RDI,FlashDL,FlashBP,JFlash,GDBFULL Checking target voltage... Target voltage: 3.33 V Listening on TCP/IP port 2331 Connecting to target...Connected to target Waiting for GDB connection...Connected to 127.0.0.1 Reading all registers Read 4 bytes @ address 0x00000000 (Data = 0x1FFFEAC8) Target interface speed set to 1000 kHz Resetting target Halting target CPU... ...Target halted (PC = 0x00000504) R0 = 00000000, R1 = 00000100, R2 = 00000105, R3 = 4004A000 R4 = 1FFFE2E8, R5 = 1FFFE358, R6 = 00000000, R7 = 1FFFEAB0 R8 = DB3B2388, R9 = 10285E50, R10= A86A2104, R11= 070A2A24 R12= 0445AA03, R13= 1FFFEAC8, MSP= 1FFFEAC8, PSP= 10835080 R14(LR) = 00000669, R15(PC) = 00000504 XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000 CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00 Reading all registers Select auto target interface speed (2000 kHz) Flash breakpoints enabled Semi-hosting enabled (VectorAddr = 0x08) Semihosting I/O set to TELNET Client SWO disabled succesfully. Connected to 127.0.0.1 Connected to 127.0.0.1 Connected to 127.0.0.1 Connected to 127.0.0.1 |
5个回答
这是什么情况啊?反删除
不知道呢,同问
看数据,刚开始是可以连接上板子的啊
他娘的,终于知道了,JLINK要升级
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2810 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2420 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2288 浏览 0 评论
2404 浏览 1 评论
1643 浏览 1 评论
/9
GMT+8, 2025-12-2 08:59 , Processed in 0.711153 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1200
