服务器附带的电源线DP / N 0N08NH具有1个6针和8针连接器。
M60卡带有一个带有2个8针连接器的加密狗。 这将使2个引脚保持未连接状态。 这会导致问题吗? 我的戴尔代表没有帮助。 一直未能找到M60电源接线规格。 以上来自于谷歌翻译 以下为原文 Power cable DP/N 0N08NH that came with the server has 1 6 pin and an 8 pin connector. The M60 card came with a dongle with 2 8 pin connectors. This will leave 2 pins unconnected. Will this cause a problem? My Dell reps have not been helpful. Have not been able to find M60 power wiring specifications. |
1个回答
嗨...你需要零件号[490-BCDP] R730 GPU安装套件(这是我订购了几台带有M60 GRID的R730设备时的订单)。
这是一篇很好的文章,显示了连接器和连接过程,这应该有所帮助:https://jhmeier.com/2017/02/01/crashing-xenserver-7-with-nvidia-m60-and-dell-r730/ 大端进入GRID,另外两个需要适应去辅助电源。 这在上述文章中很好地展示。 以上来自于谷歌翻译 以下为原文 Hi... You need the part number [490-BCDP] R730 GPU installation kit (this is what I had ordered back when I got a couple of R730 units with M60 GRIDs). Here is a good article showing the connectors and the connection process, which should help: https://jhmeier.com/2017/02/01/crashing-xenserver-7-with-nvidia-m60-and-dell-r730/ The big end goes into the GRID, the other two need to be adapted to go to the aux power supply feeds. This is shown nicely in the above-mentioned article. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2976 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3387 浏览 4 评论
GMT+8, 2024-9-18 05:40 , Processed in 0.655134 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
