电子发烧友论坛|
大家好,我正在尝试使用带有benchvue的PXA N9030A频谱分析仪。
我可以正确连接到仪器。 它上面显示绿色刻度线。 当我启动频谱分析仪应用程序时,它会尝试连接,并在一段时间后仪器自动断开连接。 我没有错,没有。 简单地说,绿色的勾号变成了红色的X ......任何人都可以在这方面帮助我吗? 我使用Windows 8.1 PC.编辑:raghavasimhan.t于2015年11月5日上午9:07 以上来自于谷歌翻译 以下为原文 Hello all, I am trying to use a PXA N9030A spectrum analyzer with benchvue. I can connect to the instrument properly. It shows the green tick mark on it. When I launch the spectrum analyzer app, it tries to connect and after sometime the instrument disconnects automatically. I get no error, nothing. Simply the green tick becomes a red X... Can anyone help me in this regard? I use a Windows 8.1 PC. Edited by: raghavasimhan.t on Nov 5, 2015 9:07 AM |
3个回答
使用LAN时,我们的IO库可能已经识别出仪器有多种协议--VXI-11,SOCKETS和HISLIP,而BenchVue使用的协议不起作用。
要解决此问题,请右键单击底部仪器栏中的仪器,然后单击“刷新”。 这将把乐器“分成”几个。 然后双击每个,直到找到有效的那个。 它可能是列表顶部ID字符串中带有“INSTR”的那个。 这是VXI-11协议,应该适用于所有情况。 仪器发现服务运行时会随机发现这些协议,因此,无论何时断开并重新连接仪器,或重新启动仪器,或任何重置LAN时,都必须执行此过程。 布赖恩 以上来自于谷歌翻译 以下为原文 When using LAN, the instrument has probably been identified by our IO Libraries with multiple protocols - VXI-11, SOCKETS and HISLIP, and the one being used by BenchVue isn't working. To fix this, right click on the instrument in the instrument bar at the bottom, then click "Refresh". This will "split" the instrument into several. Then double click each one until you find the one that works. It is likely to be the one with "INSTR" in the ID string at the top of the list. This is the VXI-11 protocol and should work in all cases. The protocols are discovered randomly when the Instrument Discovery service runs, so this procedure may have to be done whenever the instrument is disconnected and reconnected, or after a reboot, or when anything resets the LAN. Brian |
ws2165946 发表于 2018-9-11 15:37 您好Brian,感谢您的及时回复。 我尝试刷新仪器,但它并没有像你说的那样分裂成很多。 我只有一台乐器。 我该怎么办? 谢谢 以上来自于谷歌翻译 以下为原文 Hello Brian, Thanks for your prompt reply. I tried refreshing the instrument but it does not split into many as you said. I just have one instrument only. What shall I do? Thanks |
请转到右上角的齿轮图标并选择“报告问题”,它会压缩所有日志并创建一封直接发给我的电子邮件,我可以看看。 如果你可以添加一些屏幕截图,那也不错。 Brian Wood BenchVue支持 以上来自于谷歌翻译 以下为原文 Please go to the gear icon in the upper right corner and select "Report an Issue", it will zip up all the logs and create an email that will come directly to me and I can take a look. If you can add some screen shots, that would be nice too. Brian Wood BenchVue Support |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 06:04 , Processed in 1.623099 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2296
