嗨,我的公司(专注于打印机和绘图仪研究)正在加入一个R + d项目,我们需要一个具有以下要求的可编程电源模块: - 10到12个电源输出,为几个模块供电。
- 软件可编程以控制电源行为。 - 电压平衡可配置(dV / dt) - 通过软件限制电流 - 输出/输入过压和欠压保护 - 功率输出可调,步长为50mV,范围为32V-52V此电源模块应放置在机架中,并通过LAN或类似设备连接 到工业PC,UPS等......你现在的目录中是否有这样的电源模块或任何类型的解决方案可以提供这种功能? 如果没有,你可以推荐一些适合的其他特定架构(换向矩阵,pci模块,pxi ..等)吗? 在此先感谢您,随时向我询问任何细节。 以上来自于谷歌翻译 以下为原文 Hi, my company (focused on printers and plotters research) is joining a R+d project in which we will need a programmable power module with the following requirements: - 10 to 12 power outputs to feed several modules. - Software programmable to control the power behaviour. - Voltage conmmutation configurable (dV/dt) - Current limitation via software - Output/input overvoltage and undervoltage protection - Power output adjustable in steps of 50mV, range 32V-52V This power module should be placed in a rack and connected via LAN or similar to an industrial PC, an UPS, etc... do you have such a power module or any kind of solution in your current catalogue that could provide this functionality? If not, may you recommend me any other specific architecture (commutation matrix, pci modules, pxi.. etc..) that could fit? Thanks in advance and feel free to ask me for any detail. |
2个回答
您好我们有模块化电源系列,可以满足您的要求。
产品系列可配置为每个主机有4个输出,因此您的配置需要3个主机和10-12个电源模块。 有关更多产品详情,请参阅以下链接。 [http://literature.cdn.keysight.com/litweb/pdf/N6700-90001.pdf?id=2076851]问候,PaulEdited:paulf于2015年8月3日下午2:55 以上来自于谷歌翻译 以下为原文 Hello We have modular power supply family that can meet your requirements. Product family can be configured with 4 outputs per mainframe, so your configuration would require 3 mainframes with 10-12 power supply modules. Refer to link below for further product details. [http://literature.cdn.keysight.com/litweb/pdf/N6700-90001.pdf?id=2076851] Regards, Paul Edited by: paulf on Aug 3, 2015 2:55 PM |
jinxibin 发表于 2018-9-11 08:34 谢谢,这正是我们所寻找的。 最好的祝福。 以上来自于谷歌翻译 以下为原文 Thank you, that is exactly what we were looking for. Best regards. |
只有小组成员才能发言,加入小组>>
1283 浏览 0 评论
2371 浏览 1 评论
2188 浏览 1 评论
2062 浏览 5 评论
2946 浏览 3 评论
1103浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
750浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
921浏览 0评论
1283浏览 0评论
GMT+8, 2024-12-22 10:55 , Processed in 1.307515 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
