电子发烧友论坛|
我继承了使用2012 Hyper-V / Fail-over Cluster / Windows VDI构建的系统。
我正在尝试使用Server 2016 Hyper-V(1607)和戴尔R740机箱中的Tesla V100 32GB GPU推出RemoteFX。 许可证门户中的最新网格驱动程序(391.81)安装正常,Hyper-V管理器可以看到该卡并允许它用于RemoteFX。 但是,当我将其添加到VM并尝试启动VM时,我收到错误32788.(“VMName”无法更改状态。操作失败,错误代码为“32788”)。 尝试了新的虚拟机,包括第1代和第2代,以及当前的虚拟机。 如果我在硬件中包含RemoteFX 3D适配器,无论设置如何,VM都会拒绝启动。 它尝试可能1-3分钟,然后在GUI弹出窗口中报告错误32788,它无法启动。 如果我删除虚拟RemoteFX适配器,它会正常启动。 有任何想法吗? 以上来自于谷歌翻译 以下为原文 I've inherited a system that is built using 2012 Hyper-V/Fail-over Cluster/Windows VDIs. I'm trying to roll out RemoteFX using Server 2016 Hyper-V (1607) and a Tesla V100 32GB GPU in a Dell R740 chassis. Latest grid driver (391.81) from the license portal installs fine and Hyper-V Manager can see the Card and allow it to be used for RemoteFX. However, when I add it to a VM and try and start the VM I get an error 32788. ("VMName" failed to change state. The operation failed with error code '32788'). Tried new VMs, both Gen 1 and 2, as well as current VMs. The VM refuses to start if I include a RemoteFX 3D adapter in the hardware, no matter what the settings. It tries for maybe 1-3 minutes, then reports error 32788 in a GUI popup, that it couldn't start. If I remove the virtual RemoteFX adapter it starts fine. Any ideas? |
1个回答
为了防止其他人遇到类似问题,我将其缩小为继承系统上的GPO。
一旦我确定了导致它的设置,我就会回复。 以上来自于谷歌翻译 以下为原文 Just in case anyone else has a similar issue, I've narrowed it down to a GPO on the inherited system. As soon as I pin down the setting that's causing it, I'll respond back. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3818 浏览 4 评论
/9
GMT+8, 2025-12-1 19:50 , Processed in 0.706399 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4126
