您好,我们有一个非常成熟的产品,现在已经使用RN 171 6年了。我们在R&D文件中有文档显示RN 171曾经支持PEAP(企业WPA2)。有没有RN171固件的Beta版本/IMG,支持RADIUS?如果不是,为什么在执行“获取一切”命令时,在RN171上设置EAPHID?我们真的需要RADIUS,我们一直是RN171超过10K的忠实客户。有人能和我联系吗?我已经成功地在我们的设备上安装了2.33-EAP版本;在我们的R&D文件夹中找到了一个固件映像。顺便说一下,在我们的R&D文件夹中,我找到了一个连接半径的方法:设置一个A.1981 .175.253.161FTP RAP099IMGFTP U PEAP-23。IMGSAVReBooStCub默认值,然后:所有参数都设置这些设置:设置W s& lt;ssid & gt;\支持PEAP(不包括角度括号)的AP设置w u& lt;用户名& gt;\这是您的PEAP网络用户名WP & lt;密码& gt;\这是您的PEAP登录密码集WK LAN连接1SAEVIEW BooT。
以上来自于百度翻译 以下为原文 Hello, we have a very mature product and have been using the RN 171 for 6 years now. We have documentation in our R&D files showing that the RN 171 at one time DID support PEAP (Enterprise WPA2). Is there a beta version/img of the firmware for rn171 that will support Radius? If not, why is eap_ID in the settings dump on an RN171 when you do a "get everything" command? We really need radius, and we have been a loyal customer of over 10k units of the rn171. Can someone contact me with answers? I have successfully put version 2.36-EAP on our device; a firmware image I found in our R&D folders. By the way, in our R&D folders I found a method for connecting to radius that goes like this: set f a 198.175.253.161 ftp r eap099.img ftp u peap-236.img save reboot Set Factory Defaults, then: Set All Parameters Then set these settings: set w s set w u set w p set wk lan join 1 save reboot |
8个回答
我建议打开一张支持票,从McCiffpTp://www. McCHIP.COM/Sputp/HoTopopIC.ASPX作出响应。
以上来自于百度翻译 以下为原文 I suggest opening a support ticket for a response from Microchip http://www.microchip.com/support/hottopics.aspx |
我做到了,没有回应。很难驾驭票提交下落,以适当地路由机票。
以上来自于百度翻译 以下为原文 I did that, no response yet. It's hard to navigate the ticket submission drop downs to route the ticket appropriately. |
你有机器人生成的自动响应吗?(表示你的票确实被接受了)
以上来自于百度翻译 以下为原文 Did you get the bot generated auto response ? ( indicating that indeed your ticket was accepted ) |
我只需要更多的Stukes,比如6是AuthMod的CARRXT设置。SET WAUT6显然是PEAP。我应该做0, 5还是其他未经证实的Auth-Mod模式?
以上来自于百度翻译 以下为原文 i just need a few more setails; like whether 6 is the corrext setting for Auth Mode. set w auth 6 Apparently 6 is PEAP. Should i be doing 0, 5, or some other undocumented auth mode? |
在我的经验中,你现在应该期待另一个带有访问号码和电话号码的电子邮件来调用Microchip支持。
以上来自于百度翻译 以下为原文 In my experience you should now expect another email with an access number and a phone number to call Microchip Support. |
我做到了吉姆,你说得对,12小时后我就明白了。当然,我收到了他们的语音信箱。我一直在对他们的支持进行判断,直到我和支持的人打交道…吉姆,你似乎比Microchip自己更有帮助!我很感激。
以上来自于百度翻译 以下为原文 I did Jim, you are correct; I got that after 12 hours. And, of course, I got their voicemail. I'm reserving judgement on their support until I actually deal with someone from support... Jim you seem to be more helpful than Microchip themselves! I appreciate it. |
不客气。我有几年的经验在微芯片上学习我的方法。这可能有助于添加一个链接到你的第一个帖子在这个线程上的票券。
以上来自于百度翻译 以下为原文 You are welcome. I have quite a few years experience learning my way around Microchip. It might help to add a link to your first post in this thread on the ticket customer notes. |
只有小组成员才能发言,加入小组>>
5018 浏览 9 评论
1925 浏览 8 评论
1864 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3080 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2149 浏览 5 评论
585浏览 1评论
452浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
482浏览 0评论
382浏览 0评论
IPECMD命令烧录AVR128DA48芯片,报找不到芯片错误
864浏览 0评论
GMT+8, 2024-8-24 18:10 , Processed in 1.304006 second(s), Total 93, Slave 76 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
