您好,我有一个25LC512问题的DO输出水平下降。附加范围示踪显示我的意思…绿色的DO和更高的水平是3.3V(VCC),它下降到2.2和1.2V,当它是信令。这不是一个范围问题,我甚至孤立了DO引脚从电路和问题仍然存在。我更换了设备并注意到了同样的问题。我甚至尽可能地在设备上做面包板,并注意到了同样的情况。我也尝试了弱/强拉,以及弱下拉-同样的问题。有人有什么想法吗?谢谢您!
以上来自于百度翻译 以下为原文 Hello All- I have a 25LC512 issue where the DO output level is dropping out. The attached scope trace shows what I mean... Green in Do and the higher level is 3.3V (VCC) and it drops to 2.2 and 1.2V when it is signalling. It's not a scope issue and I have even isolated the DO pin from the circuit and the problem remains. I replaced the device and noted the same problem. I even went as far as to breadboard the device and noted the same. I also tried weak/strong pull up as well as a weak pull down - same issue. Anyone have any ideas? Thank you! Attached Image(s) |
2个回答
通常它会发生短路,GND或另一个引脚驱动低,YEP…
以上来自于百度翻译 以下为原文 Usually it happens as a short-circuit with GND or another Pin driven low, yep... |
达里奥,谢谢你。就是这样。只是花了一段时间才找到。
以上来自于百度翻译 以下为原文 Dario, Thank you. That was it. It just took awhile to track down. |
只有小组成员才能发言,加入小组>>
5183 浏览 9 评论
2005 浏览 8 评论
1932 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3178 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2229 浏览 5 评论
739浏览 1评论
626浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
511浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
637浏览 0评论
535浏览 0评论
GMT+8, 2024-11-28 01:40 , Processed in 1.256512 second(s), Total 80, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
