电子发烧友论坛扫一扫,分享给好友
WIBNI有用户对象或功能的非必需输入引脚,如控制输入?
也许在Vee 7.01? --Regards,Rich =================== Richard KleinhenzWafer Engineering845-892-2617scubaman@us.ibm.com============= == “哈特利,LL拉里(6245)@至:VRF IS” CC:> ---您当前订阅的VRF为:scubaman@us.ibm.comTo订阅发送空白邮件到“join- vrf@it.lists.it.agilent.com“。要取消订阅,请发送一封空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要发送邮件到此邮件列表,请发送电子邮件至”vrf @ agilent。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。#### Collector.vee已于2003年11月14日由本文删除 Kleinhenz ---您目前订阅vrf为:r***@soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“离开” -vrf@it.lists.it.agilent.com“。要向此邮件列表发送邮件,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 WIBNI there were non-required input pins for user objects or functions, like control inputs? Maybe in Vee 7.01? -- Regards, Rich =================== Richard Kleinhenz Wafer Engineering 845-892-2617 scubaman@us.ibm.com =================== "Hartley, LL Larry (6245) @ To: VRF IS" cc: > --- You are currently subscribed to vrf as: scubaman@us.ibm.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". #### Collector.vee has been removed from this note on November 14, 2003 by Richard Kleinhenz --- You are currently subscribed to vrf as: r***@soco.agilent.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
4个回答
Vikram,当您在win2K机器上安装OCX时,是否有安装屏蔽器,您只需将其复制到硬盘上即可。
我相信在VEE可以看到Active Xcontrol之前必须先注册它。 我的另一个建议是检查Active X创建者,并确保你支持XP。 那些对我来说最明显.Mark -----原帖-----来自:Vikram Boyapati [mailto:boyapati@axiom-micro.com]发送时间:2003年11月13日星期四下午6:58 VRFCc:'Simon Parfitt'主题:[vrf] Active X控件参考或者西蒙已经知道解决方案了。 不久前,我开始使用TVicLPT Active X控件写入PC的并行端口。 它一直运作良好。 我安装的第一个系统是在Windows 2000机器上。 Active X控件.ocx文件已加载到C:/ WINNT / SYSTEM32目录中。 (我忘记了如果我手动将文件复制到该目录)。现在我编写了我的VEE程序的运行时版本.vxe。 我进入了我的第二台机器,这是一台Windows XP机器。 我将.ocx文件复制到C:/ WINDOWS / SYSTEM32目录并尝试运行VEE运行时版。 显然,它抱怨它无法找到Active Xcontrol。 所以我认为,因为VEE运行时程序是由Windows 2000机器上的C:/ WINNT / SYSTEM32目录中的Active X控件引用构成的,并且因为XP机器上不存在该目录,所以我应该在 Windows2000机器上的Active X控制文件.ocx在公共目录中同时用于Windows 2000和Windows XP.So在我的Windows 2000机器上,我将.ocx文件复制到C:/ ProgramFiles / Agilent目录,删除.ocx文件 C:/ WINNT / SYSTEM32目录。 转到我的VEE程序并在Active X Control参考下,确保Active X控件的路径确实是C:/ ProgramFiles / Agilent。 我运行程序,它的工作原理。 所以现在我在Windows 2000机器上创建了这个程序的运行版本。我在Windows XP机器上运行程序(将.ocx文件复制到C:/ Program Files / Agilent目录之后)。 我认为这应该解决问题,但现在它抱怨Active X控件还没有注册。我在这里遗漏了什么? 我在VEE帮助页面中读到,当浏览Active X控件时(更改.ocx文件的位置时),VEE会尝试“注册”它。 此注册可能已在Windows 2000机器上的开发版本中自动启动。 在我的Windows XP机器上使用VEE运行时版本,如果这是问题,我怎么能注册Active X控件。非常感谢任何帮助.Vikram BoyapatiTest EngineerAxiom Microdevices,Inc .---您目前订阅了 vrf as:mrgold@pacbell.net要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent”。 “。要发送邮件到这个邮件列表,请发送电子邮件至”vrf@agilent.com“。如果您需要邮件列表的帮助,请发送邮件至”owner-vrf@it.lists.it.agilent.com“.-- - 您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“leave-vrf @” it.lists.it.agilent.com“。要发送邮件到这个邮件列表,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 Vikram, When you installed the OCX on the win2K machine was there an install shield or did you just copy it to the hard disk. I believe that the Active X control has to be registered with windows before it can be seen by VEE. The other suggestion I have is check with the Active X creator and be sure the one you have supports XP. Those would be the most obvious to me. Mark -----Original Message----- From: Vikram Boyapati [mailto:boyapati@axiom-micro.com] Sent: Thursday, November 13, 2003 6:58 PM To: VRF Cc: 'Simon Parfitt' Subject: [vrf] Active X Control reference Perhaps Simon already knows the solution. Sometime ago, I started using the TVicLPT Active X control for writing to the parallel port of the PC. It has been working quite well. The first system I installed it was on a Windows 2000 machine. The Active X control .ocx file got loaded into the C:/WINNT/SYSTEM32 directory. (I forget if I manually copied the file to that directory or not). Now I make up a runtime version .vxe of my VEE program. I get onto my second machine which is a Windows XP machine. I copy the .ocx file into C:/WINDOWS/SYSTEM32 directory and try to run the VEE runtime version. Obviously, it complains that it can't find the Active X control. So I figure that since the VEE runtime program was made up with the Active X control reference in the C:/WINNT/SYSTEM32 directory on the Windows 2000 machine and since that directory does not exist on the XP machine, I should make up the runtime program on the Windows 2000 machine with the Active X control file .ocx in a common directory to both Windows 2000 and Windows XP. So on my Windows 2000 machine, I copy the .ocx file to the C:/Program Files/Agilent directory, delete the .ocx file in the C:/WINNT/SYSTEM32 directory. Go to my VEE program and under Active X Control references, make sure that the path of the Active X control is indeed C:/Program Files/Agilent. I run the program, it works. So now I create a runtime version of this program on the Windows 2000 machine. I run the program on the Windows XP machine (after copying the .ocx file to C:/Program Files/Agilent directory). I thought this should solve the problem, but now it complains that the Active X control has not been registered. Am I missing something here? I read in the VEE help pages, that when browsing for Active X controls (when changing locations of the .ocx file), VEE tries to "register" it. This registration might have happened automatically in the Development version on the Windows 2000 machine. With a Runtime verison of VEE on my Windows XP machine, how do I get it to register the Active X control, if that's the problem. Any help would be greatly appreciated. Vikram Boyapati Test Engineer Axiom Microdevices, Inc. --- You are currently subscribed to vrf as: mrgold@pacbell.net To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
Rick,在你的情况下遇到的问题是无论你多少次ping UserObject框的序列引脚(在顶部),itCAN'T执行直到它的所有输入引脚都有数据。
在循环完成之前不会发生这种情况。 如果您使用VEE的“显示数据流”,并在WatchObject内部观察,您会看到它仅触发一次,当inout引脚“B”上有“9”,并且“XEQ”输入引脚上有一个ping。我知道 这并没有直接解决你的问题,但你要改变你的逻辑以适应规则.Mike Groves -----原始消息-----来自:Rick Hart [mailto:rhart@suptech.com]已发送 :2003年11月13日星期四下午7:30:VRFS主题:[vrf] vrf:如何在用户对象中使用收集器?Hello VEE用户,我的VEE程序开始看起来非常意大利面。 我的问题是:我不能将所有那些可爱的小收藏家放入用户对象(或功能)并继续收集数据........ XEQ引脚不会在收集器对象不在时触发 与For Loop对象相同的环境。 现在我知道你们中的一些真正的经验丰富的人现在正在窃笑,但请再一次幽默我。 引导我走上美好的道路。非常感谢.---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。 要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 Rick, The problem you are faced with in your situation is no matter how many times you ping the sequence pin (on the top) of the UserObject box, it CAN'T execute until it has data on ALL its input pins. That won't happen until the loop has completed. If you use VEE's "Show Data Flow", and watch inside the UserObject, you'll see it only fires once, when there is a "9" on inout pin "B", and a ping on the "XEQ" input pin. I know this does not solve your problem directly, but you are going to have to change your logic to fit the rule. Mike Groves -----Original Message----- From: Rick Hart [mailto:rhart@suptech.com] Sent: Thursday, November 13, 2003 7:30 PM To: VRF Subject: [vrf] vrf: How do I use a collector inside a user object? Hello VEE users, My VEE program is beginning to look pretty spaghetti-ish. My problem is: I can't put all those lovely little collectors into user objects (or functions) and continue to collect data into them........ The XEQ pin won't fire on the collector object when it's not in the same environment as the For Loop object. Now I know some of you real seasoned veterans out there are snickering right now but please humor me just one more time & lead me down the rosy path. Many thanks. --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
HI Karl,这里是示例程序你可以看到发送到excel format.regards的日期和时间,satheesan NairOn 2003年11月14日8:04,Karl Doody写道:主题:[vrf]时间戳输出到Excel?
发送日期:2003年11月14日星期五08:04:09 -0000来自:“Karl Doody”收件人:VRF发送回复:“Karl Doody”>嗨,>>有谁知道如何将当前时间输出到Excel,因为我 有>数据记录VEE编程,似乎无法获得时间戳输出>工作。 >>>谢谢> Karl。>此电子邮件由UAV Engines Ltd.发送>仅供目标收件人使用。>该邮件可能包含特权或机密信息。>如果您不是 特此通知收件人,严禁使用,>分发或复制本通讯,>并要求您删除电子邮件和任何附件>并立即通知发件人。>> --->您是 目前订阅vrf为:satheesan@netcominc.com>订阅发送空白电子邮件至“join-vrf@it.lists.it.agilent.com”。>要取消订阅,请发送空白电子邮件至“leave-vrf @ it。 lists.it.agilent.com“。>要将邮件发送到此邮件列表,请发送电子邮件至”vrf@agilent.com“。 >如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。> Satheesan NairManufacturing EngineerNetcom Inc599 Wheeling RoadWheeling,IL 60090Ph:847-537-6300传真:847-537- 5162 以上来自于谷歌翻译 以下为原文 HI Karl, here is the sample program you can see how the date and time sending to the excel format. regards, satheesan Nair On 14 Nov 2003 at 8:04, Karl Doody wrote: Subject: [vrf] Time Stamp Output to Excel ?? Date sent: Fri, 14 Nov 2003 08:04:09 -0000 From: "Karl Doody" To: VRF Send reply to: "Karl Doody" > Hi, > > Does anyone know how I can output the current time to Excel as I have > Data logging on a VEE prog and can't seem to get a time stamp output > working. > > Thanks > Karl. > This e-mail message has been sent by UAV Engines Ltd. > and is for the use of the intended recipients only. > The message may contain information that is privileged or confidential. > If you are not the intended recipient you are hereby notified that any use, > distribution or copying of this communication is strictly prohibited, > and you are requested to delete the e-mail and any attachments > and notify the sender immediately. > > --- > You are currently subscribed to vrf as: satheesan@netcominc.com > To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". > To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". > To send messages to this mailing list, email "vrf@agilent.com". > If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". > Satheesan Nair Manufacturing Engineer Netcom Inc 599 Wheeling Road Wheeling, IL 60090 Ph:847-537-6300 Fax:847-537-5162 |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 23:44 , Processed in 0.656314 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2024
