我有一个XC16 USB软件包(用于XC16Pro编译器),并尝试在两台笔记本电脑上安装Pro编译器——一个是Win 10的惠普笔记本电脑,另一个笔记本电脑是Win 10的联想。两台笔记本电脑都有MPLAB X IDE V4.20安装。在HP笔记本电脑上,我做了以下操作:1)卸载XC16编译器的所有版本,这些版本都是免费版本。2)在安装结束时运行“XC16-V1.35-WiDOWS安装程序。exe”3,当被请求主机ID时,我放入“软件狗”。然后我启动了MPLAB X IDE 4.20,在编译器工具链的仪表板上,出现了一个第三行:“许可证:工作站-PRO--按状态”。太好了!它在惠普笔记本电脑上工作。我在联想笔记本电脑上做了同样的事情。但是Compiler Toolchain下的第三行,“许可证:工作站- PRO -按状态”,从来没有出现,好像没有安装PRO编译器。我甚至去卸载MPLAB X IDE 4.20,删除它的相关文件夹,重新启动笔记本电脑,重新安装MPLAB X IDE 4.20,并重新安装PRO编译器以上相同的步骤。但是无论出于什么原因,PRO编译器和MPLAB X IDE 4.20都没有捆绑在一起。USB驱动器或USB HW问题?我如何解决这个问题?非常感谢您的帮助。
以上来自于百度翻译 以下为原文 I got a XC16 USB dongle (for XC16 PRO compiler) and tried to install the PRO compiler on two laptops - one is HP laptop with Win10; the other laptop is Lenovo with Win10. Both laptops had MPLAB X IDE V4.20 installed. on the HP laptop, i did the following in order: 1) uninstall all versions of XC16 compiler, which were free versions. 2) run "xc16-v1.35-full-install-windows-installer.exe" 3) at end of installation, i put in "DONGLE" when asked for HOST ID. (USB dongle was plugged in). then i started MPLAB X IDE 4.20, in the dashboard under Compiler Toolchain, a 3rd line showed up: "License: Workstation -PRO --Press for Status". - Great! it works on the HP laptop. I did the same thing to the Lenovo laptop. but the 3rd line under Compiler Toolchain, "License: Workstation -PRO --Press for Status", never showed up, as if the PRO compiler wasn't installed. i even went far to uninstall MPLAB X IDE 4.20, delete its related folders, reboot the laptop, reinstall MPLAB X IDE 4.20, and reinstall the PRO compiler per the above same steps. but for whatever reason the PRO compiler and MPLAB X IDE 4.20 are not tied together. USB driver or/and USB HW issue? How am I trouble shooting this issue? Your help is greatly appreciated. |
3个回答
我没有打扰联合国安装XC8或XC32,只是插入了加密狗,它是由许可证管理器自动发现,并消失了。虽然我没有XC16,但它应该是即插即用,当加密狗插入时,PRO许可证是有效的。我高兴地在Mac和PC之间使用Gielle,并将它们映射到VM的我以前的项目环境中,当我需要重访一些旧的。它们以USB驱动器的形式出现,因此应该作为驱动文件挂载,您可以用-DeNeLeNeo运行XCLM命令来查看编译器是否可以看到它。
以上来自于百度翻译 以下为原文 I didn't bother un-installing either XC8 or XC32, just plugged the dongle in and it was spotted by the licence manager automatically and away it went. Although I don't have an XC16 one. It should just be plug and play, the PRO licence is active when the dongle is plugged in. I move happily between Mac and PC with the dongles, and also map them to VM's I have of previous project environments when I need to revisit something older. They appear as USB drives so should just mount as a drive letter You can run the xclm command with -dongleinfo to see if the compiler can see it. |
谢谢你,RJC101!你是如何在第一的地方安装XC8或XC32的?当安装了MPLAB X IDE时,默认情况下没有安装编译器。我们必须一次一个地下载和安装编译器。在安装XC16V1.35的情况下,在我的情况下,主机ID被要求-如果NIN MAC地址应该被输入,如果从网络NIC MAC地址生成了许可证;如果许可证在USB加密狗中,则应该进入“加密狗”。在所有这些步骤之后,软件狗就像您所说的那样工作。在我的HP笔记本上玩。但不是我的联想笔记本电脑,我很困惑!
以上来自于百度翻译 以下为原文 Thank you, rjc101! how did you install xc8 or xc32 in the 1st place? when MPLAB X IDE was installed, by default no compiler was installed. We had to download and install the compiler, one at a time. At the end of installing xc16 v1.35 in my case, HOST ID was asked - NIC MAC address should be entered if the license was generated keyed off the network NIC MAC address; "DONGLE" should be entered if the license was in USB dongle. After all these steps, the dongle just works just like you said, plug and play on my HP laptop. but not on my Lenovo laptop. I am puzzled! |
我刚刚安装了从主下载链接的编译器,它运行正常,我只留下主机ID到默认的MAC地址。我想我只是把它们安装在默认的免费模式中,它把MAC地址自动地作为主机ID。然后,软件狗只需即插即用,就我所能记住的,从默认的提示中什么也没有改变。
以上来自于百度翻译 以下为原文 I just installed the compilers from the main download links, it ran through as normal and I just left the host ID to the default MAC address. I think I just installed them in default free mode and it put the MAC address in automatically as the host ID. Then the dongles are just plug and play, nothing changed from just following the default prompt as far as I can remember. |
只有小组成员才能发言,加入小组>>
4926 浏览 9 评论
1876 浏览 8 评论
1817 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3018 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2106 浏览 5 评论
520浏览 1评论
375浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
426浏览 0评论
313浏览 0评论
IPECMD命令烧录AVR128DA48芯片,报找不到芯片错误
796浏览 0评论
GMT+8, 2024-7-16 14:31 , Processed in 1.237398 second(s), Total 81, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
