正如在我上一篇文章中我试图找出一大批未知的freq mobile&
便携式天线。 我一直试图找到他们设计的频段,使用8720分析仪设置为S11返回损耗,然后切换到史密斯图表检查50欧姆。 问题是它们没有接近我认为应该是的频率,即使是已知的工厂天线也应该更高或更低。 我错过了什么吗? 以上来自于谷歌翻译 以下为原文 As in my previous post i am trying to identify a big batch of unknown freq mobile & portable antennas. I have been trying to find the bands they were designed for by using 8720 analyzer set to S11 return loss and then switch to smith chart to check for 50 ohms. Problem is that they are not coming up close to the frequency i think they should be, even a known factory antenna also comes up either higher or lower that it should be. Am i missing something here? |
1个回答
最常见的错误之一是认为谐振天线为50欧姆。
它可能不是(完全取决于馈电点阻抗设计)。 此外,如果天线调谐到50欧姆,并且您的分析仪没有使用良好的50欧姆负载校准,那么您的明显史密斯图表中心将是校准负载的阻抗,而不是50欧姆。 请记住,在谐振附近,阻抗几乎与频率线性变化,从低于50欧姆到高于50欧姆,所以看起来频率的变化实际上可能是阻抗的变化。 最后,地平面对阻抗有很大影响,因此您可以考虑如何提供地平面。 我想知道你是否想在两个相似的天线之间做一个单独的S21,看看它们在哪里有最大增益。 以上来自于谷歌翻译 以下为原文 One of the most common mistakes is to think that the antenna at resonance is 50 ohms. It may not be (depends entirely upon the feedpoint impedance design). Also, if the antenna is tuned to 50 ohms, and your analyzer is not calibrated with a good 50 ohm load, then your apparent smith chart center will be the impedance of the calibration load, not 50 ohms. Remember, near resonance, the impedance changes almost linearly with frequency, from below 50 ohms to above 50 ohms, so what appears as a shift in frequency may really be a shift in impedance. Finally the ground plane has a really big effect on impedance, so you might consider how you are supplying ground plane. I wonder if you might want to do a separate S21 between two similar antennas to see where they have maximum gain. |
只有小组成员才能发言,加入小组>>
1133 浏览 0 评论
2321 浏览 1 评论
2114 浏览 1 评论
1985 浏览 5 评论
2859 浏览 3 评论
879浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
648浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
750浏览 0评论
1448浏览 0评论
1133浏览 0评论
GMT+8, 2024-10-20 12:46 , Processed in 1.415338 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
