主函数代码如下
int main(void) { /*!< At this stage the microcontroller clock setting is already configured, this is done through SystemInit() function which is called from startup file (startup_STM32f10x_xx.s) before to branch to application main. To reconfigure the default setting of SystemInit() function, refer to system_stm32f10x.c file */ u16 i, len, c2len; u16 x; u16 y; u8 c[] = "www.armjishu.com"; u8 c2[] = "TFT LCD 320X240"; u8 *str; u16 charColor; u16 bkColor; len = sizeof(c)-1; c2len = sizeof(c2)-1; /* USARTx configured as follow: - BaudRate = 115200 baud - Word Length = 8 Bits - One Stop Bit - No parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = 115200; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; STM_EVAL_COMInit(COM1, &USART_InitStructure); /* Output a message on Hyperterminal using printf function */ printf("nrUSART Printf Example: retarget the C library printf function to the USARTnr"); printf("rnnn WWW.ARMJISHU.COM %s configured....", EVAL_COM1_STR); printf("nr ############ WWW.ARMJISHU.COM! ############ ("__DATE__ " - " __TIME__ ")"); printf("rn"); printf(" _____ _______ __ __ ____ ___ ______ __ ___rn"); printf(" / ____|__ __| \/ |___ \__ \| ____/_ |/ _ \rn"); printf("| (___ | | | \ / | __) | ) | |__ | | | | |_ __rn"); printf(" \___ \ | | | |\/| ||__ < / /| __| | | | | \ \/ /rn"); printf(" ____) | | | | | | |___) / /_| | | | |_| |> |
6个回答
没人么??
慢慢 缩小包围圈,看问题出在哪?
回复第 3 楼 于2013-03-12 22:25:14发表:
慢慢 缩小包围圈,看问题出在哪? 就是那个printf函数那块,原来做串口的时候它工作就不正常。我做个彩屏,要USART串口功能干嘛,我把它注释掉,彩屏就不好使,不知道什么原因呢 |
要找原因,可以慢慢地注释掉不需要的,步子不要太大;(要不,留着串口输出也没什么大碍,需要的时候还可以用用 )
回复第 5 楼 于2013-03-13 08:57:41发表:
要找原因,可以慢慢地注释掉不需要的,步子不要太大;(要不,留着串口输出也没什么大碍,需要的时候还可以用用 )好吧 |
ili9320_Initializtion();函数中用了串口发送
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2797 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2403 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2276 浏览 0 评论
2388 浏览 1 评论
1637 浏览 1 评论
/9
GMT+8, 2025-12-1 23:45 , Processed in 0.725048 second(s), Total 84, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2757
