电子发烧友论坛|
PIC32 MZ2048 EFM100 HORDER 2.04i AM在函数中运行DSP1 FieldFixIM32()时存在问题。DSP滤波功能,DSPFILTERFIL32()没有内部抽取,工作良好。相同的数据,相同的抽头,相同的系数,相同的输入缓冲器大小。一个大约50%次的惩罚。函数dSP.FielFieldIM32()似乎完成并返回,但是应用程序停止运行。我猜测它触发了一个异常或中断,这些异常或中断是不被处理的,事情从那里开始下坡。我如何捕获和处理异常或中断,这是我没有预料到的?你如何调试这样的东西?我使用以下参数,我相信满足抽取函数的规则。输入缓冲器大小=200个采样缓冲器大小=40个采样率=5TAPs=系数个数=延迟线长度=8个尺度=0(无位移位)---格雷厄姆==
以上来自于百度翻译 以下为原文 PIC32MZ2048EFM100 HARMony 2.04 I am having problems getting the function DSP_FilterFIRDecim32() to run in a program. The DSP filter function, DSP_FilterFIR32() without the internal decimation, works fine. Same data, same taps, same coefficients, same input buffer size. I could use this function, and separately decimate, but at about a 50 percent time penalty. The function DSP_FilterFIRDecim32() seems to complete and return, but the application stops running. I am guessing that it triggers an exception or interrupt that is not handled, and things go downhill from there. How do I catch and handle an exception or interrupt that I am not expecting? How do you debug something like this? I am using the following parameters, which I believe satisfies the rules for the decimation function. Input buffer size = 200 samples Output buffer size = 40 samples Decimation rate = 5 Taps = Number of coefficients = Delay line length = 8 Scale = 0 (No bit shifting) --- Graham == |
相关推荐 |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
475 浏览 0 评论
5794 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 11:49 , Processed in 0.538060 second(s), Total 72, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1572
