我使用PIC32 MX795F512L为我的项目的1。我需要在我的应用程序读取4针输入DIP开关状态。有很多其他的GPIO的我正在使用,他们都在正常工作,然而,RG2和RG3它不工作。如果这2个引脚是低的,然后在控制器上,他们读取它们为高。如果两个引脚状态不同,那么我可以正确地读取它们。我禁用USB和使用这只是一个GPIO。我经历了不同的职位,只发现这个引脚只是输入,但没有人发布任何问题与输入。下面是代码的一部分。{ PraccMang-CopIg PascMod=HS,FNOSCC=PrPLL,FPBDIV= DIVII2α-PrAPMA配置,WDTPS=PS8192GPIO::定义DIP1BIT Tras-TrISA3*定义DIP2BIT Tras-TrISA2定义DIP3BIT Tras-TrISG2定义定义DIP4BIT Tras-TrISG3α定义DIP1BITαRA3定义DIP2BITαRA2定义DIP3 VY2,FPLLoDIV= DIVIG1,FWDTEN= OFF摩哂陀位定义了DIP4BY位RG3DIP1BITTYRIS=输入;DIP2BITTYRIS=输入;DIP3BITTYRISIS =输入;DIP4BITTYTRIS =输入;如果有人能帮助,请让我知道。谢谢,,
以上来自于百度翻译 以下为原文 I am using PIC32MX795F512L for 1 of my project. I need to read 4pin input dip switch status in my application. There are plenty of other GPIO's I am using and all of them are working properly however with RG2 and RG3 it's not working. If this 2 pins are low then on controller they read them as high. If both pin status is different then I can read them properly. I disabled USB and using this as an GPIO only. I went through different posts and only found this pins are only Input but no one posted any issue with Input. Below is part of code. Config -: #pragma config ICESEL = ICS_PGx1 #pragma config FCANIO=ON #pragma config FUSBIDIO = OFF // USB USID Selection (Controlled by Port Function) #pragma config FVBUSONIO = OFF // USB VBUS ON Selection (Controlled by Port Function) #pragma config FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FPLLODIV = DIV_1, FWDTEN = OFF #pragma config POSCMOD = HS, FNOSC = PRIPLL, FPBDIV = DIV_2 #pragma config WDTPS = PS8192 GPIO-: #define DIP1_BIT_TRIS _TRISA3 #define DIP2_BIT_TRIS _TRISA2 #define DIP3_BIT_TRIS _TRISG2 #define DIP4_BIT_TRIS _TRISG3 #define DIP1_BIT _RA3 #define DIP2_BIT _RA2 #define DIP3_BIT _RG2 #define DIP4_BIT _RG3 DIP1_BIT_TRIS = INPUT; DIP2_BIT_TRIS = INPUT; DIP3_BIT_TRIS = INPUT; DIP4_BIT_TRIS = INPUT; Let me know if anyone can help. Thanks, Mahendra |
2个回答
你是如何连接VUSB3V3的?它应该连接到VDD,使RG2/RG3被用作GPIO。
以上来自于百度翻译 以下为原文 How have you connected VUSB3V3? It should be connected to VDD to enable RG2/RG3 to be used as GPIO. |
嗨,Simong,VUSB现在没有连接,我会把它连接到VDD并检查它是否有效。谢谢您。
以上来自于百度翻译 以下为原文 Hi Simong, VUSB is not connected right now I will connect it to VDD and check if this works. Thank you. |
只有小组成员才能发言,加入小组>>
5184 浏览 9 评论
2005 浏览 8 评论
1932 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3179 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2230 浏览 5 评论
742浏览 1评论
629浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
512浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
640浏览 0评论
538浏览 0评论
GMT+8, 2024-11-29 02:02 , Processed in 1.301784 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
